Jacking Points And Axle Stands
Can someone confirm whether a jacking pad like the one within the link above is suitable for a LWB T6.1 or whether there's a pad specifically made for the T6.1?
Cheers.
Don’t know about that particular one. But I’ve gone through a bunch of different pads and seems T5/T6 (and T6.1 is afaiu the same) always cuts to them after a while irrespective of pad rating - the shape of the jacking points is pretty unforgiving. The pads end up looking like unsafe swiss cheese pretty quickly.
I haven’t found any pads designed especially for Transporters - doesn’t mean they don’t exist though.
For now I’ve settled on a larger and thicker block -style pad, so far it has fared better than any of the round smaller ones ever did.
Cheers.
It was not deep enough so it got chewed up eventually.
I've been searching for a couple of hours and so far haven't come across anything that's bespoke for the van. I'll go for what looks the most substantial - thanks.
I’m jacking her up either from subframe near where control arm connects to (front) or under control arm itself (front + rear) and place stands under normal jacking points.
This gives the widest support when on stands. Jacking from under arms is bit inconvenient though as they’re not level - good pad needed
Does that mean here which is the rear of my 6.1 lwb?
