Just about finished fitting my footwell lights and it's been a bit of a tale of woe for me unfortunately....I wish you hadn't said that now....
@saxoboy Morning mate could you send me the details to purchase a set of your footwell lights please?
cheers Tonto
@Tsixty in the picture have you installed @Saxoboys ambient lighting kit with the 2x red leds or are you referring to the footwell lighting kit?So, I finally got round to finishing off this install. The lights look great thanks @saxoboy I can confirm that if you have this front lighting unit the wiring is slightly different:
You still need to tap into the red/black wire in connector block T10ab (white one) as per the instructions, but you will find that there isn't a red/brown wire in the white connector. You need a red/brown wire from connector block T17k (green one). There are two red/brown wires in T17k - the correct one is the thinner of the two and is on pin 17 which is the end pin of the middle row (the other end of the middle row isn't used so it is easy to find).
Very happy I now have the footwell lights working and managed to fathom out which wire/connector from the wiring diagram. Says something that it has taken me 3 months to find the time to actually go out and wire it up. Hope this info helps someone else from scratching their head when a 10 minute job turns into a longer one because the wire you expect to find in a connector isn't there.
MattHi @Rhodders, @Tsixty is explaining the installation of the footwell lights (actually I didn't know it would be slightly different to install in a van with cabin lights like yours, please follow Tsixty's instructions, when you install your footwell kit and use the red/ brown thin wire in the green connector).
The ambient lighting kits I supply are like the below picture, its a totally different light fitting, that will not fit in your vans cabin area....sorry, as discussed off line.
...Matt
@Rhodders I only installed the footwell lighting kit. The red ambient overhead lighting kit that @saxoboy sells definitely will not fit if you have the same switch unit as me.@Tsixty in the picture have you installed @Saxoboys ambient lighting kit with the 2x red leds or are you referring to the footwell lighting kit?
I ask since i have the same front lighting unit with elec sunroof dial, and Saxoboy said the ambient lighting kit would not fit this type of unit, so i am confused? But, I have also got to fit the footwell lighting kit so very useful info either way thanks!
hi got a new t6.1Hi does the footwell kit come with a light for each foot well and how easy is it to fit the glove box light?
Hi Matt, did you get my PM regarding the puddle lights?Hi @tinctina obviously you haven't' got my footwell lights that go off when you close a door, or when your in the van, turn off after a set time.....they certainly should do, or your battery will drain....Matt
