Finally got round to doing my own variation on on the overhead ambient cabin lighting. The kit
@saxoboy supplies doesn't work for those of us that have the alternative roof console, so I did mine myself. The middle trim piece where the 2 LEDs are fitted pops out if you start at the edge closest to the windscreen. On the reverse there are already two perfectly placed dimples in the moulding to drill two 6mm holes. The LEDs then just clip in. Pop the panel off with the sunroof dial, again it comes off edge closest to the windscreen first and in there you can tap into the wires that illuminate the dial, which are controlled by the dash illumination dimmer switch so they will dim with the rest of the instrumentation. I forgot to take a picture but the two wires are obvious, they are the only two that go alone into a black connector on the dial (the other connector on the dial has 5 wires in it) the -ve is brown the +ve is grey with a blue trace I think. All in all once I got round to it 15 minute job.
