Good news, i have managed to get hold of new stock now so the LED illuminated bars are now back in stock in the shop and available ready for delivery
SWB = £409.99 VIP member discount price £404.99
LWB = £454.99 VIP member discount price £449.99
VW T6 Sportline Chrome Angled Sidebars With LED Puddlelights
Each bar has a wire coming from it that enters the van under the respective seat each side, from here there are prewired/preterminated cables that run up through A pillars and connect to front interior roof light this then activates the puddle lights when you lock/unlock vehicle and open doors etc ..... but it is done this way to make it suitable for all vehicles, if you have a kombi then you have a rear step light and the interior lighting all activates/deactivates together (PV doesnt) so you could keep all wiring low level under floor etc and connect to step light cabling instead either at the step light or nearer the front seats as this wiring comes from passenger seat area anyway but would require cutting of the plugs that come with the step lights shortening the cable and joining to the existing loom somewhere@Pauly Oooooo!! Very very interested in a SWB set, how do the lights work/where are they wired to?
This will sound random but have you switched everything off, walked away and had a brew and come back an hour or so later? I had issues with the rear door not showing as closed when it was and it was just the hyper sensitive T6 system throwing a tantrum. Disconnect the battery.. walk away. Reconnect.. try again.HELP interior lights stay on ! I fitted the sport line sidebars with puddle lights purchased from the T6 shop as per the instructions, ran cables into the light console as per plug n play instructions into the cab, firtsly the fuse in the fuse holder was blown so replaced that and lights all worked with a lovely puddle underneath each door, but when turning ignition on the interior lights stay on, that's in the cab and the rear. I disconnected the puddle lights and still the same, I removed the splitter cable for the puddle lights and replaced the original into the cab light and rear lights go out but cab lights stay on, this means the interior lights and puddle lights will stay on whilst driving unless I manually turn them off, the lights do extinguish when I lock the van, checked all connections and all look good - really apreciate any advice/ideas?
Hmmmm my only other suggestion is to do as Pauly suggested and wire them into the rear door step lights...Thanks guys, but disconnecting battery didn't work, I've slammed all the doors and MFD shows them as shut, now at a loss what to do next, also no faults showing on VCDS..............any ideas gratefully receivend
I had nearly same problem when fitting side door power latching interior light and step staying on but mfd was showing side door open when it was closed.HELP interior lights stay on ! I fitted the sport line sidebars with puddle lights purchased from the T6 shop as per the instructions, ran cables into the light console as per plug n play instructions into the cab, firtsly the fuse in the fuse holder was blown so replaced that and lights all worked with a lovely puddle underneath each door, but when turning ignition on the interior lights stay on, that's in the cab and the rear. I disconnected the puddle lights and still the same, I removed the splitter cable for the puddle lights and replaced the original into the cab light and rear lights go out but cab lights stay on, this means the interior lights and puddle lights will stay on whilst driving unless I manually turn them off, the lights do extinguish when I lock the van, checked all connections and all look good - really apreciate any advice/ideas?
How are you getting on with this, any progress ?HELP interior lights stay on ! I fitted the sport line sidebars with puddle lights purchased from the T6 shop as per the instructions, ran cables into the light console as per plug n play instructions into the cab, firtsly the fuse in the fuse holder was blown so replaced that and lights all worked with a lovely puddle underneath each door, but when turning ignition on the interior lights stay on, that's in the cab and the rear. I disconnected the puddle lights and still the same, I removed the splitter cable for the puddle lights and replaced the original into the cab light and rear lights go out but cab lights stay on, this means the interior lights and puddle lights will stay on whilst driving unless I manually turn them off, the lights do extinguish when I lock the van, checked all connections and all look good - really apreciate any advice/ideas?
Fixed my issue, the lesson is don't trap cables and short them out in the A pillar,
