OK, this could end up a little long winded...
I have a 110(iirc)a/h leisure battery charged by a ctek ds250e going to a 12 way fuse box. It feeds, fridge permanent 12v, tap/in tank pump, ceiling lights, map reading lights, usb's, cig lighters.
I rewired my leisure electrics this year to add a main leisure battery cut off (via a heavy duty 200a relay) so i can fully disconnect it. I also added some small relays for the tap, shower pump and a fridge temperature controller (the fridge compressor main 12v feed is still direct from the fuse box, no switch).
These are now controlled by small rocker switches mounted in the overhead cubby hole, adjacent to which I've added a permanently live 12v led voltage readout/display.
The switch feeds (for the coils, ie. Pins 85/86) for the small relays are taken from the 12 way fusebox and the main heavy duty cut off relay switch feed is straight off the leisure battery with an oinline fuse.
Straight after the main relay I also added a maxi blade fuse box (that then feeds the existing 12 way fuse box and ctek) and also added an earth busbar - so I don't have to connect everything to the battery ie. just one main (+) and one main (-) coming off the batt terminals.
Before I did this I had no way of turning the leisure electrics off and mutliple wires coming off the battery terminals so it seemed a logical way to do it....
Prior to this work I'm sure the leisure battery would hold charge indefinitely, ie. 12.8 - 12.9v pretty much constant, so I'm guessing its something I've changed.
The voltage now seems to drop over a few days, I haven't used the van for a good 5 days and it is down at 12.1 volts, this is with nothing switched/running. If I isolate the leisure battery via the main relay then it will hold its charge, ie. when switched back on it will be around 12.8/12.9 volts no matter how long it has stood. The relay cuts the leisure battery off completely, i.e from the ctek as well.
-What is the current draw from the coil on the main relay? 12v planets relay guide suggests 150-200mA? (Should I have wired the relay as as NC ie. used a 5 pin relay so that the coil isn't drawing current all the time whilst the leisure battery is on?)
-The 12v led voltmeter, would this draw much current/mA? I am going to change this so it can be switched on or off, probably via a momentary switch, as its too bright at night whilst trying to sleep and I really only need ro check voltage occasionally.
If neither of those are causing that level of battery drain then I guess I have other issues. I can measure the current drain at the battery and pull fuses until it drops to isolate which circuit it is on?
Any advice welcome and if a diagram is needed I will try and get one drawn up, I have a very rough one somewhere in the garage.
Cheers.
Cheers.
