Ok I will bare it in mind, thanks for the advice
Did you have the '100' split charge relay under the passenger seat?Hi mate, back home and looking into this now. All Rac stuff removed and that battery still charges from the alternator so happy days.
Do you know where the ignition signal is or which cable im looking for?
On my previous van, a T5.1, it had the factory second battery & split charge relay. I left the relay in place & used the output from the relay to feed the B2B, basically putting the B2B in series with the relay & the second battery. Worked a treat & when I sold the van, it was a simple job to put it "back to factory".Yeah I have that relay, should be easy to spot then, I know first 3 are there.
Thanks mate, will go test now.
Some don't need it or have an option to use it, some need it and others can either use the signal wire or use voltage detection.What are you using the run signal from the alternator for? I had a little look at a couple of DC-DC chargers and not sure where you would put it?
YesIs the Split charge relay the 100 in my attached photo?
can someone explain the difference, or reason, between the current split charger and installing a dc-dc charger?
1. Personally, I would connect my solar to the LB side of the DC-DC & fit something like an Ablemail AMt-12 to keep the SB topped up. Plenty of folk use this method & it works well. Fitting the solar to the SB side might fool the DC-DC into thinking that the engine is running (Depending on how you've configured the DC-DC), this could result in the DC-DC draining the SB.Hi. I’ve been reading loads and loads of these threads at the moment (often till the early hours ) getting my head around the SCR and retro fitting a DC to DC instead ( I have ‘22 plate T6.1 with OEM LB fitted under passenger seat). I’m planning in next few weeks to swap out my SCR too.
Info is great . However quick question and clarification of my understanding. (I have read. LOADS of post and searched to death but probably missed it). Or tied myself in knots.
1. If occasionally a solar is fitted direct into the DC to DC (say parked up on drive for period) as I understand this will trickle charge both SB AND the LB? ( I’m thinking of adding a panel to roof bars just to top up/use when van is idle and plug in on a couple of Anderson or similar connectors). Just like this great post from r00ps ( thanks… just what I need to do mine).
T6.1 factory aux battery split charge relay upgrade & solar panel install.
Hi, I had the factory fitted aux battery ( under a single seat with swivel base ) fitted to my T6.1 with the intention of using it as a camper leisure battery. After getting less than impressive performance and reading about how the split charge relay is a pretty bad charging method I wanted to...www.t6forum.com
2. With the DC to DC module fitted in place of SCR with OEM wiring, will ‘priority’ be given to charging SB or LB with engine running (or does alternator just feed both in parallel).
3. From what I’ve read DC to DC will allow LB to charge to 100% instead of capped 80%, so will ditching SCR for DC then also allow SB to charge to 100% (either by solar or driving) or is this 80% ceiling for SB governed by A/N other bit of kit?
Honestly my sincere apologies if this has been asked (somewhere) I have searched and read and read but it might be a case of ‘can’t see wood for trees’. Also apologies if I’ve misunderstood.
Thanks in advance.
Rob
