Leisure battery - using the 240 socket Sargent Ec 155
GazGringe
Hi all. I've got the Sargent ec155 electrical system. When on leisure battery, the socket doesn't work. It works when on hookup. My wife is planning to go on a writing retreat for her PhD so will need this and maybe without electric hookup for few days. Is this a fault with the electrical system?
The basic EHU setup has the socket wired direct outside.
As above you need an inverter fitted.
Some install s will have a dedicated inverter socket.
More complex install will have a transfer switch over to use the same socket s.
Post some pics of what you have.
What kit are you planning to plug in when off grid? - this will give you an idea of what size inverter is needed.
What wattage is the laptop power brick?
You could get a small 100-200w that will cover that.
Bellow 90ish watts you can plug into a 12v socket.
Above 90w I'd be hard wireing it the leasure battery.
Then just run a small extension lead to give you a 240v socket run from the inverter....
I have a couple of these....
Post a few pics of your electric setup and leisure battery....
i have a a swap over switch from hook up to invertor supply to the sargent......invertor sorts me out when no hook up. bit of a faff but works a treat, if invertor not happy for any reason, which its norm fine as a big unit... you can run the engine so its keeping it happy with a bit more supply voltage, microwave, kettle etc..
@Dellmassive You said below 90w it’s fine to run from the 12v socket but the inverter you’ve shared is a 300w with a ciggy plug. Would you not use that near full whack then?
