Lithium LifePo4 12v Batteries - Time For An Upgrade?
Low temp cut off is a must, and your covered there which is good.
For the heater - where's the van stored when you're not driving it, and it's it in regular use or is it just for summertime and trips away?
The heater might come in useful if it's stored during winter, as with an AMT-12 and a solar panel, you can basically keep the starter battery and leisure battery topped up with no hookup or additional chargers needed, provided it can get enough solar. If you regularly have cold days in winter, no heater might scupper this. Even 15w of solar is 1amp and might be enough to keep everything topped up over winter. It'll depend entirely on now much solar the van would get and how many days below zero you have.
On the BMS side, the Victron app is easier to access than the Fogstar app, and you're already going to be using it with your other Victron kit. 1 app Vs 2.
As for the BMS inaccuracies - that could be a bigger issue if you think you'll be running the battery down to 20% or lower regularly - even with normal use you'll very likely not see the correct % on the BMS, due to low solar days, or just using a few lights etc. so you might find that you're in a situation where you think you have 15% but the battery suddenly cuts off because it's actually at 0%.
Nice one, thank you. The van is a daily driver so the only time it doesn't get driven is the weekends basically. Should have said, the panel is one of the suitcase ones so it's not permanently connected.
I like the idea of having all the data in one app and, as I said, I do trust the Victron kit.
In the summer we went to Scandinavia and got quite good solar, but our AGM battery couldn't quite cope with the fridge so the battery voltage being available in the MPPT app was really handy. With more capacity in the lithium I imagine we are less likely to run it flat, but I suppose knowing an accurate SOC is important for us.
So, save up for a bit longer and get the 105ah battery AND the Smart Shunt?
I don't think you'll really see a benefit from a heater, in that case. There might be a couple of days a year when you've got solar out and it's too cold to charge but the fact that you've not got permanent solar means they probably won't be very often.
I'd go for the 100Ah drift ECO and the smart shunt. 5Ah is not worth worrying about.
Brilliant. Thanks for the advice...
Actually just triple checking - low temperature protection prevents the battery from being charged, so the DC-DC charger won't damage it if below freezing?
Correct, the battery BMS will stop any charge coming in from actually charging the battery when it's below freezing. You can just leave the chargers to do their thing as normal, the battery BMS will block the charge.
You can still discharge the battery below freezing (so it'll power your fridge etc), that's all fine - but charging a LiFePO4 battery below zero is a big no-no.
We have the Fogstar Drift 105 and it has been brilliant. So much better than our traditional lead acid leisure battery. Fit and forget.
It can power the fridge, lights, diesel heater and phone chargers for days. It’s combined with a PV Logic 100w panel, PV Logic MPPT charger, Victron Bluesmart 30a charger, and an Ablemail DC to DC.
We had an issue with the battery not reporting the correct SOC to the app. Fogstar support were really good. We just had to charge the battery until it reached 14.2v and it reset the BMS.
Recommended.
I'm still weighing up the Fogstar Eco over the Drift to replace my AGM. Hope this isn't a daft question but trying to fully understand built in heating on the Fogstar Drift - I have a Victron XS DC-DC (with engine running hardwired to it) and no permanent solar charging. I understand the leisure battery heating function would only draw power from a charging source and doesn't self-consume power. So if the van is parked up and the temperature goes sub-zero, the battery heating won't come on, and will only switch on, powered from the Victron DC-DC when the engine starts? Just confirming there's no way leisure battery heating can switch on and flatten the starter battery when parked up.
Correct. If there's a charge current coming into the battery and the temperature is below the cut off, the battery will just limit the current and send it to the heater until it reaches 5 degrees when it'll then allow full charge current to the battery itself.
Skimmed through this thread. Lots of useful information, although it has become apparent I need to do more reading.
I have a Victron dc/dc charger, so from what I've understood, there's no reason I can't swab my current lead 110ah (c100) battery for a 100ah lithium one? I understand the Victron settings will need to be changed.
Also, I don't think I have a EHU charger (or I certainly can't find it if I do have one!). To tell for certain is it as easy as having a multimeter on the battery with and without hook up in place?
If I were you I'd be happier knowing what is installed and how it's connected and protected. So assuming you have EHU, does this go to a consumer unit with 230V breakers? If so can you identify what is on each of the breakers? Mine has a main incomer breaker then three separate circuits - one for the 230 / 12V battery charger, one for the mains sockets inside the van and one for a hot water heater. You should be able to work out what is what by a process of elimination. The leisure battery volts should in theory rise when a charger is connected to it but may not if the battery is full.
Yes it looks like my consumer unit has three circuits. One is labelled sockets, one labelled power supply and one is main isolator. I'll see if I can work out what the power supply one is.
The consumer unit is in the wardrobe and my dc/dc charger is under driver's seat. With the leisure battery. I can't in all honesty imagine where the EHU charger would be if there is one.
I just don't want to fit a lithium battery inappropriately!
