Load area LED bulbs go out after a few seconds...
SWF7Y
Hi guys, bit of help needed. I have a T6 kombi, I've changed all the lights to LED and added some LED spotlights too. Problem I have is, they don't stay on for long enough when I open the tailgate. Literally a few seconds. Is this something I can change with VCDS? TIA
Thanks for that. I'm a noob when it comes to VCDS so hopefully it won't be too difficult to find.
mmi is right... should be default value of 21 in Channel 38 which equates to 10.5 minutes..?
See whats in there and let us know....
Reactions: mmi
Battery seems fine. Starts ok. I'll check VCDS tomorrow and see what is there. Hopefully I can find it easily
Right, plugged it in this morning. It was set at 21 so I am thinking it is a battery issue. Is it just a case of taking it on a run to recharge or something more sinister? Also, a list of faults popped up when I did a scan. See below20210112_093717.jpg
Reactions: mmi
We'd need to see the individual faults. Can you post a scan?
Code:
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXHA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KL    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 6166
   Revision: 23002001
   Coding: 00194014432501090000
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KL 004012
   ROD: EV_ECM20TDI03004L906056JS_004.rod
   VCID: 010930039009038E1C-8054
4 Faults Found:
15560 - EGR Sensor 1
          P046C 00 [096] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 176841 km
                    Date: 2046.01.07
                    Time: 10:33:19
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 16 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 12.601 V
                    Unlearning counter according OBD: 20
                    Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Spec.value: 4.66 %
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 16.00 %
                    Exhaust recirc.valve 1 bank 1: posit.feedback -Offset closed.: 0.00 %
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Uncnd vlt: 2.566 V
                    EGR vacuum regulator solenoid valve 1 bank 1: res. Cooling mode stop: 2.280 V
                    EGR vacuum regulator solenoid valve 1 bank 1: res. Bypass operation stop: 2.569 V
15918 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [039] - Electrical Fault
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 181459 km
                    Date: 2049.01.00
                    Time: 11:40:28
                    Engine speed: 950.25 /min
                    Normed load value: 25.1 %
                    Coolant temperature: 4 °C
                    Intake air temperature: 9 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 11.843 V
                    Unlearning counter according OBD: 40
                    Preheat time: 2.5 s
                    Glow status: Post-heat
                    Extern.temp.sens.1 bank 1: raw value: 5.5 °C
33262 - Reductant System Performance Bank 1
          P204F 00 [096] - Malfunction
31103 - SCR NOx Catalyst Bank 1
          P20EE 00 [104] - Efficiency too Low
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 121
                    Mileage: 170756 km
                    Date: 2045.01.03
                    Time: 06:14:25
                    Engine speed: 1998.00 /min
                    Normed load value: 60.0 %
                    Vehicle speed: 112 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 13.414 V
                    Air mass at air mass meter 1: 172.8 kg/h
                    Extern.temp.sens.1 bank 1: raw value: 11.5 °C
                    Mass airflow sensor 1 bank 1 airflow: raw value: 719.8 mg/stroke
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 55.47 %
                    NOx sensor before SCR cat conv: offset correction factor: 0 ppm
                    NOx sensor after SCR cat conv: offset correction factor: 111 ppm
                    Reducing agent quality sensor: urea concentration: 0.00 %
                    Reducing agent quality sensor: raw temperature value: 0.0 °C
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 42556000000133
   Coding: 347E4098656784852C7E0276A68621D3790000
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 3F8DF6FBA67DB57E2A-806A
1 Fault Found:
0397 - TPMS Warning
          C102D F0 [008] - Pressure Loss
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 243
                    Mileage: 180951 km
                    Date: 2020.11.17
                    Time: 10:57:28
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 20091613470889
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7661-802A
No fault code found.
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 AJ    HW: 7E0 907 047 AJ
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis.rod
   VCID: 72EB6FCFA5AF281615-8026
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 263161351
   Coding: B8FC793A0A61341193284F746EEB9EFD0F84710F60CC6D60320400230840
   Shop #: WSC 02737 534 739161
   VCID: 2A5BB7AF45FF20D66D-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 010916 04  42  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 P    HW: 7E0 959 801 P
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU014091662583900
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 P    HW: 7E0 959 802 P
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU013091662578345
   Coding: 0400A0
   Subsystem 4 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 5 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
   Subsystem 6 - Part No: 7E1 951 172
   Coding: 000000
   Subsystem 7 - Part No SW: 7E0 959 442     HW: 7E0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29160001731720096355
   Coding: B0FFFF
3 Faults Found:
03434 - Output for Terminal 30G Interior Lights
            007 - Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 245
                    Mileage: 181443 km
                    Time Indication: 0
                    Date: 2020.12.19
                    Time: 12:23:13
03302 - Response Closing Status of Passenger's Door
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 180770 km
                    Time Indication: 0
                    Date: 2020.11.12
                    Time: 14:08:51
03224 - Play Protection Active
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 242
                    Mileage: 181060 km
                    Time Indication: 0
                    Date: 2020.11.23
                    Time: 14:22:39
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 T    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0212
   Revision: --------    Serial number: 32961622103525
   Coding: 108008
   ASAM Dataset: EV_VW75XParkAssis4K 001013
   ROD: EV_VW75XParkAssis4K_001_VN75.rod
   VCID: 4385FA0BCA95D19E4E-8016
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag021 H08 0018
   Revision: --------    Serial number: 003V30024HV5
   Coding: 000000000000000000000000000000003231
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3A7B87EFBD5F90561D-806E
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
   Component: KOMBI         H03 1104
   Serial number: 00000000000000
   Coding: 140B010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 042305
   VCID: 68DF0DA79B73D2C6BB-803C
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 1104
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6ADB77AF8D7FE0D6AD-803E
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L
   Component: MU-E-D-ER     055 7067
   Serial number: 01091600013094
   Coding: 065700003C00000041111101008000001F0000C60000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2E53BBBF71174CF6B1-807A
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Component: J367-BDMConti  H03 1050
   Serial number: 75410903001609021417
1 Fault Found:
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 7
                    Fault Frequency: 86
                    Reset counter: 241
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2020.07.27
                    Time: 23:32:42
[Code/]
I copied and pasted everything. Sorry
Any chance to post the VIN of the van to better identify the type of the van - just leave 5 last digits off. Also what's the mileage in the scan?
Got a bit curious of seeing in the scan: 121 incidents :unsure: of fault 31103 - SCR NOx Catalyst Bank 1 - P20EE 00 [104] - Efficiency too Low
But you don't have the EML light on? (Yellow engine symbol)
Last 5 of VIN [redacted]
mileage is 112k
No EML light on dash.
What does fault 31103 relate to? I'm hoping these faults are easily rectified as I've only just bought the van and can't afford to spend loads on it :oops:
Reactions: mmi
Sorry about poor wording. Actually it was the beginning of the VIN that's the interesting bit. By looking the other components I'm assuming it's actually?
WV1ZZZ7HZHH***** thus N1 class (=panel van/Kombi) and model year 2017.
Fault 31103 indicates elevated NOx level - which was an annoying issue. However, recent engine software should have taken care of that issue. The update should have fixed also false alarm of fault 33262, which also was logged.
The interesting bit is that it looks like your engine has got an update - which woke up my curiosity.
Yours:
Without update it would have been:
Was the van with you at 106103 miles (170756km)?
Any chance you could do the following with VCDS and post the result file?
VCDS -> Applications -> Controller Channel Map ->
Tick/fill boxes as above and hit Go
VCDS flashes screens for a moment (when finished hit "Done, Go Back") and there will be files adpmap-01-... and blockmap-01-... in folder C:\Ross-Tech\VCDS\Logs\....
Then just upload/attach the files here.
Apologies deviating from your original problem. However, the
suggests there was possibly too low voltage for a moment: Date: 2020.12.19 Time: 12:23:13.
Yes it is a 2017 Kombi. I bought the van maybe 6 weeks ago. I didn't have it at 106k. Any idea why it may have been updated and the 31103 left un-updated?
I'll plug VCDS in in the and report back with the findings. Also, no need to apologise. Any help is very much appreciated.
Could suggest a fault on the lighting circuit
Thanks. Do you know how I may be able to investigate this?
I'd start by removing all the bulbs you've replaced with the originals and see if the lights stay on as they should. If they do, replace each bulb individually and test after each.
