Think it best to start with video and work backward
This is where the disclaimer goes. This is what I did, no idea if safe or allowed so best to check before you even think about trying it out.
I took the lock/unlock switch apart to find out how it worked.
Basics are when unlock is pressed it connects the yellow wire to earth. When lock is pressed it connects the yellow to earth via a
7686Ω resistor.
Next step was to piggy back the existing yellow wire direct from the BCM. I took this new wire from the BCM and an Earth to a breadboard. Then attached two switches and to get the resistance spot on I used a 501 potentiometer and 1K resistor in parallel. (As the resistor on the switch board was an 86A with a 1% tolerance.)
When I hit the buttons and the switches worked a treat.
As a test, I played about with the resistance values switch fails about +- 10 % 850 690.
Good news is there is no need to faff about the resistor VW use is a standard one. I have ordered 5 from Ebay £2.36 delivered, will post up a pic and circuit drawing when they arrive.
Kev
