New to the forum and have been looking to convert my T6 to a camper. Having decided to go down the lithium battery route and after reading all the info and threads from dellmasive's great write up I thought I would try and add maybe put some info back into the group.
The way in which I want to use batteries is so that I can go away for periods of time to the alps skiing and didn't want to have to worry about the temperature and charging of the battery.
So back in December I ordered a couple of the Poweroad low temp 100amp from Alpha battery:-
They have now arrived and I will be in the process of fitting them in the van over the next week.
This is the description from Poweroad:-
Description
The LINC INFI Low Temperature Lithium Battery is specially designed with heating function that can be charged at temperature down to -20°C. The process of heating and charging is automatically controlled by the BMS embedded in the battery. The operation of our low temperature battery is exactly the same as our other Lithium-ion batteries.
It takes about 40 minutes to heat from -20°C to +5°C. Once the battery temperature reaches +5°C, the charging starts immediately. And when the temperature rises to +10°C, the heating stops while charging continues, which means our LINC INFI Low Temperature Lithium Battery is the ideal battery for cold weather.
Description
