Note the two images below, both taken from other posts in this thread. Look at the Rear Toe setting tolerances. One has a toe in limit of 25 minutes, the other has a limit of 15 minutes. The 25 is the "half load" target, the 15 is the "no load" target. The top image shows that 22 minutes is acceptable, but it wouldn't be if your van is lowered and the load doesn't change, the toe in would stay at 22 minutes and wear the outer edge/tread prematurely. That would fail if the machine had been set to "no load" and correctly so. That illustrates what I have said in my previous post. A much tighter target. Just in case anyone reading this doesn't understand the minutes, it's 1/60th of a degree.@cgtmiles you must get it re-done or you are going to destroy your rear tyres in no time, trust me, I've been there! @Littleblackflash is spot on. Excessive toe in is going to wear the outer edges and tread of your tyres in about 3000 - 4000 miles with those toe numbers. Camber does not affect the wear on a T6 anything like as much as the toe. I would bin that alignment guy off and find someone who knows what they're talking about.
I'll also try and explain why you must use the "No Load" settings.....
When you have an alignment done using "half" or "full" load, the machine assumes that you are carrying more load than you normally would be, so it assumes that your van is sitting lower than it normally would. The outcome of this is that it adjusts the target "green" numbers to those for a van sitting higher than yours is.
As you lower a T6 and especially on the rear end you will get toe in and negative camber. This is simply because of the geometry of the rear arms and their mounting points.
So, the machine thinks your van is sitting lower than it normally would and adjusts the target numbers to be that for a van sitting higher, it thinks that your wheels don't usually toe in as much as they are and so it doesn't ask the fitter to correct them (as much as it should). It will allow that number to go green when they are still toeing in, assuming that when you get home and take the load out of the van it will sit higher and the toe in will reduce to correct settings. What it doesn't know is that you aren't taking any load out of the van at all, so your suspension geometry doesn't change, the wheels continue to toe in too much and you ruin your rear tyres in no time!
When you have it done with "no load" settings, the machine sets the target numbers assuming that your van runs at it's current ride height and therefore suspension geometry all the time. That means it uses the correct targets for how your van is sitting at the time of the alignment. That gives a toe in target much closer to 0 and makes sure that you get the alignment you need to look after your tyres correctly. This becomes more and more critical the lower your van goes, simply because the lower you go, the further the wheels will toe in until there is no adjustment left.
I'm about 80-85mm down and on the limit of the rear toe settings, there's no adjustment left and they are only just in tolerance on the "no load" settings. I suspect I'll still wear my rear tyres more quickly than I would like, but not as bad as the last ones. When these are worn and I get them replaced, I'll have some adjustable poly bushes fitted to help adjust the toe a bit further.
I hope that explains it, I've done my best!!
Thanks! I can go to the garage armed with a bit more info now and hopefully get it done right. Will report back.@cgtmiles you must get it re-done or you are going to destroy your rear tyres in no time, trust me, I've been there! @Littleblackflash is spot on. Excessive toe in is going to wear the outer edges and tread of your tyres in about 3000 - 4000 miles with those toe numbers. Camber does not affect the wear on a T6 anything like as much as the toe. I would bin that alignment guy off and find someone who knows what they're talking about.
I haven't suggested adjusting the toe to account for camber, I was suggesting adjusting the toe to save your tyres.Ok so yesterday I went back to the same place I went to before and the guy was still insisting that having toe in was the correct thing to do to account for the increased camber. He did adjust it though but gave a serious warning that I should check the tyres regularly as he believed they would now scrub on the inside edge.
So this is what he did, he brought the toe down to around 25’ from 35’. The images above are left=full load, right=half load.
Now what he explained about loading was that as the camber is out because of the lowering the van is always sitting at that camber and therefore the full load settings should be used, this makes sense to me. The toe etc specs change as the camber specs change so in full load (which with full conversion and most of the gear onboard it pretty much is all the time anyway) the camber is as expected and can’t be adjusted so the full load specs should be used for toe too.
I have RTEC nearby who are specialist in custom vehicles and also run a lowered T5 so I’m going to put this to them also but I just wanted to get your thoughts on this first.
The responses on here are pretty much agreed that the toe should not be adjusted to account for the camber but he was actually quite concerned that this would damage the tyres so it’s interesting that if he’s wrong then his thinking is almost 180degrees out! And I still have high toe going by the no load settings! I wanted to give them another go and they are normally good (did do the adjustment for free so I’ve just lost a bit of time if I need to go elsewhere!)
I'll knock a couple of quick sketches together to try and illustrate why the wear is on the outside because of the toe and I'll post em up in a minute.I’m sorry, I didn’t mean to question your knowledge on this I’m just trying to get it straight in my head. It is very difficult when they are saying the complete opposite to argue against them without truly understanding. I really appreciate your input and the efforts you have gone to to try and get this through my thick skull!
On that note (ie. my thick skull) you mentioned outside wear, I thought the wear would be on the inside? The excessive toe means the front of the wheels are pointing towards the centre of the van more than they should right? And with them leaning in at the top wouldn’t the wear be on the inside? This is where the fitter thought they would wear too. This question may help you understand what your dealing with here, sorry again if it’s a daft assumption
I agree, in theory excessive negative camber should lead to wear on the inside edge as it's that edge taking more load, fair enough, that makes sense, but it needs to be seriously excessive. When it comes to toe it's about direction of tyre rotation vs direction the van is travelling in.You don’t have to do that, very kind offer though, again thx for your time.
Interesting again though that he was concerned on wear on the inside edge or maybe I just made that assumption. Anyway, I will get it done with no load elsewhere.
Again, I very much appreciate the time and fort you have gone to to explain this to me. I definitely owe you a beer (at least one) if ever we meet!
I have just spoken to R-Tec, a custom car specialist in St Albans and they knew straight away what I was on about so I have it booked in for tomorrow.
Thanks again
Just found these guys, only an hour from me, anyone used them?
How did it go?I'm booked in at tuned uk tomorrow for the 4 wheel alignment thanks to fezza.... I'm pretty sure these guys know what they're doing... but I have one of the print offs which shows the 'no load' settings and i think the main point i can gather from this subject is to ask for neutral rear toe.
How did it go?
