Hi, Yes, It seemed to go well at
Tuned UK
He's a decent guy, with a quality professional set up and seems to know his stuff.
I had said that from the homework I had done I needed the 'no load' setting and a 'neutral' rear toe. He agreed that this was correct and that the front set up should be a 'parallel' set up. His system isn't a Hunter alignment one, but a more advanced system called 'Absolute Alignment'
Absolute Alignment 4-Wheel Alignment Equipment
The drive back felt much better, but that wouldn't of been hard as the geometry was quite a way out to start with... The van felt more planted to the road, more grippy, but also more responsive. There was a noticeable reduction in drift to the left and once on the motorway, it was straight as an arrow.
I have to bow to his superior knowledge that he has set this up correctly, I understand there are lots of differing views over this subject on this forum.
He did say that 0.3mm toe was as good as he could get it on the rear without the adjustable poly bushes... but such a small amount wasn't going to effect driveabilty or tyre wear significantly. However I will keep an eye on this over the coming months.
Here are the before and after reports....
