Not arrived yetDid the breakdown service test the battery or alternator?
Hate to say but the VW garage might take one look at your beefy set up and say they're not touching it. It's all non std fit and unless they know their way around a 12v camper set up they're not going to know what to test/check etc.An update for you, booked into VW garage tomorrow. Meantime bought a multimeter and confirmed 12v to fuse box + same to all points on lynx. If Ehu and/or solar on. Nothing if battery only on. In EHU/Solar mode fridge and gas showing insufficient power
So, there's something in-between your battery and your 12v feeds (starting with the lynx distributor) that's causing nothing to be drawn from the battery.confirmed 12v to fuse box + same to all points on lynx if Ehu and/or solar on. Nothing if battery only on.
Like the new multimeter you've just bought.Do you have something that you can connect directly to the battery positive and negative
You've mentioned gas not getting enough power twice now and it's really not clear what you mean.In EHU/Solar mode fridge and gas showing insufficient power
Yep, although I'm not sure how/if you can generate a load with a multimeter?Like the new multimeter you've just bought.
This 60A fuse connection nut looks a lot looser than the others and the fuse tab seems bent upwards and not in good contact with the bus bar?I would check the tightness of all the nuts on that bus bar - you may well be able to see voltage across it but if you have a loose high resistance connection a multimeter in voltage mode has almost no load and wouldn't show the issue.
Obviously be careful not to cause a short, maybe turn the battery off in the app while you check.
Same with the right hand nut (marked red). Doesn’t look like the split washer is compressed.This 60A fuse connection nut looks a lot looser than the others and the fuse tab seems bent upwards and not in good contact with the bus bar?
The fuse tab at the other end doesn't look great either
Yep edited the post to add that, probably should have replied instead and not change historySame with the right hand nut (marked red). Doesn’t look like the split washer is compressed.
Yep, that'll do it!!Good news, got the problem I think. Jump start a red herring, problem is lose cable to isolation switch!
