I used to work on an IT service desk so I'm used to troubleshooting stuff - the key is eliminating as many variables as possible and starting with the basics. I had a hunch it was going to be either the main fuse or isolator switch!Jesus this was like an episode of Colombo![]()
I've moved on from having to deal with end users now, thank Christ! But the troubleshooting skills still remain.Similar to @TallPaul_S the DayJob is mostly figuring out what people actually mean/want from what they say
Also shows why, even if it seems daft, it's always a good idea to take pictures. To be honest I've sometimes taken them of my own stuff I'm having trouble with, sometimes sitting down with a picture and a cuppa you see something you don't when you're standing next to it.
The users are fine compared to the folks running the projects and asking you fill out endless RFIs and RFPs. They're usually brilliant at tying up your time but rather less brilliant at actually noticing the invoice...I've moved on from having to deal with end users now, thank Christ! But the troubleshooting skills still remain.
Has that pulled out of a crimp or a terminal? Either way it doesn’t look like it was ever done up very tight. I’d suggest getting someone (or you) to give the system a good look over and check all the connections are tight and secure.Good news, got the problem I think. Jump start a red herring, problem is lose cable to isolation switch!
If it was working before you started the previous issues diagnostics it’s highly likely that you’ve disconnected something, maybe a fuse back in the wrong position?New problem I’m afraid. Pump (Aqua 8) now not working!![]()
Tbh that shows, it's a much beefier system than you normally see in a small van - but to start ripping some of that out to replace with smaller items would be a massive pain - it really looks like a properly well put together system ( ignoring the loose connections!).Re positioned the fuse a couple of time and it's kicked in fine.
Note observation on system, was first T6 fit out firm had done - usually does bigger vans. Can you share a link to simpler system - could do with the space back?
THANK-YOU again Team T6
