MIB2 PQ Discover Media - Infotainment mods, upgrade, FEC / SWaP
Robert
Senior Modder from Poland
VCDS User
Moderator
T6 Legend
I couldn't find any info about FEC / SWaP here on this forum, so I decided to post a little bit.
Obviously FEC is Feature Enabling Code and SWaP is Software as Product.
This is the list of my available features:
And this is the list of my installed features:
So I already have the following active:
30000 - USB
40100 - Navigation
50000 - Bluetooth
60100 - Vehicle Interface
60200 - Car-Net
60300 - Mirror-link /App-Connect
60800 - Apple Car Play
60900 - Android Auto
70200 - Voice Control
70400 - Electronic amplifier for driver
9400008 - Map of Europe
And available for activation are:
60400 - Performance Monitor/ Sport HMI
7400004 - Map ???
8400002 - Map ???
9400003 - Map ???
These are the products that I am familiar with but I am more than happy to be corrected;)
I wonder what experience others might have?
Has anybody purchased any of this codes from the stealers?
Cost? Activation/Installation? Satisfaction/Opinion?
Well, yes if you have it on your list of available features.
Hold your menu button for a couple of seconds and have a look through your available list.
By the way you can check your active features as well.;)
This has come up - I’ve got loads of sub-menu’s.. none of which look like yours with the numbers beside them.
Just try to hold you menu button for a little bit longer.
In some cases you may need to activate developer mode with VCDS in adaptations under Infotainment.
I’ve pressed and held it for 10 seconds and hear a ‘bong’ but nothing changes other than the menu that I photographed, so I guess I need VCDS. No worries mate, cheers.
Ah, I definitely don’t have that third option of FEC / SWaP
So you have the following:
40100 - Navigation
50000 - Bluetooth
30000 - USB
I am still curious what this FEC does ----> 60100 - Vehicle Interface (I have it on my active list)
Also I have available for activation this one ---> 60400 - Performance Monitor/ Sport HMI
Does this mean that we could display vehicle data, like Golf/Passat?
I would like to check mine also but I'm having a problem enabling developer mode (located in Information Control Unit 5F) using OBD11.
When trying to activate developer mode I'm getting function not available, any ideas?
Edit - Figured it out.... not 100% how but have.
Installed codes
00040100 - valid Navigation
09400008 - valid Map of Europe
00050000 - valid BT
00030000 - valid USB
00060200 - valid CarNet
So I need 00060700 for Android Auto
According to my active list "60800 - Apple Car Play" I already have it ;)
