Now there's a good idea. @DXX would win that one!We should start a "T6 Forum Nuggets of Wisdom" thread.
That and the "Doesn't Suffer Fools Gladly" award.Now there's a good idea. @DXX would win that one!
I'm sure he would resemble that remark!That and the "Doesn't Suffer Fools Gladly" award.![]()
The usual thing that catches folks out is the start up surge load, sometimes also called inrush current. The rate on the labels tends to be maximum load in steady state. At home a short surge is nothing as you have the National Grid with massive capacity, in the van there's not that capability. This is why inverters often list a surge load they can cope with for a few seconds.I love the way my induction hob draws close to 180 Amps when we boil the kettle with no issues. Yet my lesser powered coffee machine makes my inverter 'grumble' when pulling max 1400 watts. Why would that be? where is @roadtripper when you want him? Vive la France...
Without delving into the interaction between that particular machine and that inverter it's hard to say, you'd have to really look at high speed measurement on the mains side.Thank you @roadtripper , I'm still at a bit of a loss as to why the inverter whinges under the load from the Tassimo when the induction is a greater load? The Inverter with the induction hob at 2kw to boil a kettle has no issue but that blessed Bosch... The family love the Tassimo because of its ability to create wonderful hot chocolates and differing coffee, I obviously have to think of them, the wife tells me! Thank you so much for taking the time to reply, a swift beer or two due to you when we meet!
Before we get to bogged down in power factor correction and whether the CIVIL acronym applies I think this is more a case of me being a numpty and assuming that 700 watts was the microwave oven input power and not the available cooking power plus what must be a shed load of additional losses.The difference in power factor between inductive and resistive loads
As a bread and butter sparky I always thought that the capacitor on a larger motor was there to control the motor direction upon start up much as as compensate for the current lagging voltage due to the inductance of the motor field windings?Power Factor is certainly a thing too, but I think it's a lesser effect in this situation.
An attempt at a short summary:
Mains power is AC, so the voltage and current rise and fall 50 times a second.
Think of voltage like the pressure to move and the current as actual movement.
The classic intuitive resistive loads like heaters the voltage and current rise and fall together.
However inductive loads (like motors) and capacitive loads (like mains LED lights and electronic power supplies) behave differently. Remember a spinning motor as also a generator, so an inductive load also generates some voltage. Capacitors are like small short term batteries so also store and then release charge.
These effects mean that voltage and current don't rise and fall in sync, because the load is also either adding or removing voltage during the cycle.
Why does this matter? Well the whole point is to transfer power, and power is voltage x current, so if they are not in sync you end up having to have higher currents to transfer the same power.
Loads that are in sync are said have a power factor of 1, loads out of sync have a lower power factor. So for instance a power factor of 0.5 means there is twice as much power flowing in the circuit than is actually being used by the load.
That's bad for 2 reasons:
1. Your source of power (IE inverter) still has to supply that power
2. Loses in the cabling are resistive, and power loss in cabling is resistance x square of the current - so higher currents dramatically increase the losses
This is why in any industrial setting you will find that equipment has power factor correction. Because inductive and capacitive loads offset things in opposite directions you can use one to balance the other. This is why you often see a large capacitor (capacitive load) across a motor (inductive load).
Without wanting to further divert the subject yes SMPS continues to need PF correction. They're much smaller and overall efficient but as thier trick is to run a small transformer at high frequency they demand power in a very odd way that causes harmonics on the power lines. This has to be corrected in the SMPS itself, rather than en mass like classic PF loads, and is again often left out.Not sure if power factor correction is a thing these days with switch mode power supplies and thyristor soft starts on previously star/delta motor contactors?
But then you’re going to have to change the whole van system to 48V, all so you can use your hair straightenersI think the current... tee hee... problem is that we're stuck in the mind set of leisure power being derived from a 12 volt battery when maybe we should be stepping up the voltage from the alternator and juggling the solar panels to provide say a 48 volt leisure battery and reduce those huge 12 volt current values?
I did help look after a yacht with a Sea Panther(?) engine that had a wierd approach of running the engine electrics at 24v for more efficient charging but used pairs of starter and leisure 12v battery. Then a complex battery isolator would switch them between serial and parallel when you moved from running to non running.But then you’re going to have to change the whole van system to 48V, all so you can use your hair straighteners![]()
You can get electric BBQs to plug into some EVs now. Now then kids, would you rather have another burger & walk home…..I did help look after a yacht with a Sea Panther(?) engine that had a wierd approach of running the engine electrics at 24v for more efficient charging but used pairs of starter and leisure 12v battery. Then a complex battery isolator would switch them between serial and parallel when you moved from running to non running.
I get the idea but the result was that several generations of owners had simply given up and wired equipment in anywhere they could find 12v between 2 terminals and it was a nightmare.
Of course when we all move to 400/800v EV it's really easy - plug a Vehicle to Load adapter in and use as much mains as you want trading off range...
A whole new subject for family arguments await I suspect![]()
