Hi All,
Just after a little help again if I may please.
My Transporter has recently had a new Egr, Head Gasket, injector and last week failed its MOT on emissions.
Garage said the dpf was knackered at was quoted £2500-£3000 for a new one. Given the amount I’ve spent on it recently, I decided to fit a used one. I managed to source and fit a new dpf from a crashed Transporter with 28,000 on the clock for £500. I ran some cleaner through it and I fitted it and it passed the MOT emissions test.
My issue is I think the DPF is not regenerating. I think the dealer I got it from may of done a DPF delete on it, to get rid of the lights on the dash without removing the filter. In the whole time I’ve had it I’ve never noticed it regenerating. Hence it getting so blocked up it imploded and possibly caused the head gasket issue.
How can I tell if it’s had a remap to remove The DPF? I have Carista and the DPF app and both show ‘soot mass calculated’ and ‘soot mass measured’ as ‘0’. I’ve been driving for a week since fitting the new one and this value hasn’t changed. Could it just be the particle sensor is knackered?
Would appreciate some help on how to diagnose the particulate sensor or confirmation that it has been mapped out.
Thank you
Dan
Thank you
Dan
