Couldnt agree more.To me thats a 10min job to sort out and get a pass - looks like the lower nut needs checking for tightness too.
That said I think you dodged a bullet with that one![]()
Was it knocking/clunking when you drove it? That would be seriously noisey driving like that? You'd 100% notice the noise!!Received an image from VW this morning. Amazed they’re not prepared to put a bolt on it so I can drive it to be repaired.
I'm amazed that the VW van centre refused to carry out the remedial work in this situation! All that is required is to place the plate back in the correct position and fit a new top nut. They're trying to con you out of over £1000 worth of new suspension when all it needs is a new top nut! The thread on the strut shaft looks OK in that picture, but the only way I can see even the slightest reason not to carry out the work is if the thread is damaged on that shaft.Received an image from VW this morning. Amazed they’re not prepared to put a bolt on it so I can drive it to be repaired.
No can’t - too much of a major to PRSSurely, adding the nut is the repair!
Ah, so if the thread on the shaft is damaged it might be worth getting onto Stance and seeing if they can supply you with one front strut. Why the damage though? Was the nut cross threaded when the strut was installed perhaps?Nope never heard or experienced any driving issues. I'm in the mild OCD camp so a knocking, a rattle or a squeak I would notice. I would expect some feedback when steering but all has been fine.
VW responded to my request this morning to install a nut, even a temporary measure to get to the independent garage. They confirmed the tread is damaged and cannot be repaired, also would be liable so will not make any changes.
Clonking about I would thinkAh, so if the thread on the shaft is damaged it might be worth getting onto Stance and seeing if they can supply you with one front strut. Why the damage though? Was the nut cross threaded when the strut was installed perhaps?
Yep! A “Friday afternoon” job! I doubt the thread would be damaged all the way down eitherShite workmanship by the installer these don’t ever just come undone such a long thread too, it’s just been spun on with fingers to hold it in place to attach to hub and forgotten about
yeah, if the installer has forgotten to tighten that nut then the thread would easily be damaged as it knocked about. OP hasn't reported any knocking noises though. Anyway, I think I would be discussing this with the installer, if they warrant their workmanship there might be an opportunity to recover costs, even if they don't do the remedial work.Clonking about I would think
Agreed. It's not going to fall out but it would be noisey when driving which makes me question how legitimate it is... To the OP I'd pick your van up and drive it round the corner and then get it recovered somewhere else.That threaded part of the shaft takes minimal load - it simply holds the shock unit in place and most of the time the weight of the van holds it in place (as you have found) If you went over a severe bump or got airborne the nut would stop the shock falling out.
I’d be happy cleaning up the thread and putting a nut on it.
I doubt the MOT tester would pull the wipers and scuttle panel off as that is not a requirement for MOT, I suspect they could see there were issues by looking up into the wheel arch.Is it just me wondering why anyone would be under the bonnet on an MOT to even see that??
I'm thinking back to various MOTs and don't recollect any MOT places going under the bonnet.?
Unless there was an obvious mechanical knock or something when loading the van on the ramps?...to make them look out of interest?
They even get out of doing a proper job if you have a flimsy plastic lower engine covers.... saying "unable to check due to covers" something like that.
Though I am a firm believer that MOTs are very important and need to be done thoroughly for all Road users safety.
So game on to them for finding it..... but I'd like to see a pic of that they are referring too.?
Are we just saying that they have identified mechanical play in the upper shock when doing the loaded suspension checks?
Mate, from the images and details you give this appears not to be a fault of the suspension but rather the incorrect installation of a product. This could have happened on any coil over kit of any quality. Mistakes happen so before the converter gets a bashing (they deserve so here nfortunately), errors can be made in all walks of life, we like to think they don’t but they do unfortunately. This one is a basic mistake of not refitting correctly, and really should have been picked up during the tracking and test drive stages.Received an image from VW this morning. Amazed they’re not prepared to put a bolt on it so I can drive it to be repaired.
Yep exactly. The thread may be recoverable. Worst case you fit a new strut in that cornerThat threaded part of the shaft takes minimal load - it simply holds the shock unit in place and most of the time the weight of the van holds it in place (as you have found) If you went over a severe bump or got airborne the nut would stop the shock falling out.
