Repair wire VW part number 000979227E would work - for "normal/regular" (19mm wide) size blade fuses. Google search will bring up also "plain" crimp inserts.part number for the contact pins that push into the facia fuse box
VW dont sell the crimp inserts anymore, for some reason they withdrew them a few years ago and only sell the repair wires now ?Thank you so much for your help i am getting there. you wouldn't by chance have a part number for the contact pins that push into the facia fuse box to enable me to use the factory fuse locations? Drawing a blank with TPS ...they do not understand. Many thanks
The fuses are micro fuses in the facia panel unfortunately.Repair wire VW part number 000979227E would work - for "normal/regular" (19mm wide) size blade fuses. Google search will bring up also "plain" crimp inserts.
I need two contacts for micro fuses if you have any? They are needed for the fuse box connections.VW dont sell the crimp inserts anymore, for some reason they withdrew them a few years ago and only sell the repair wires now ?
I have the majority of sizes kicking around, if you get stuck let me know and will see what i can do
Thank you so much. Even TPS came up blank. I will order some tomorrow. When I finish this project I will give back to the forum what I have discovered, you have been so helpful MMIsuggests the following for repair wires (credit to "JetTurbo" on the site)adding a 5A power circuit to Fuse Box C
adding a 5A power circuit to Fuse Box C (using vacant slot, not add a fuse) I recently added a couple of 5A power circuits to the fuse box on the left side of the dash. Thought I would pass along what I learned. ---- Pop off the fuse panel cover on the left side of the dash board using a trim...www.golfmkv.com
2.8mm terminals - ATM fuse (small fuses)000 979 021 : 0.5mm wire (used for this post / pictures) (000979021)000 979 133 : 1.0mm wire (000979133)000 979 225 : 2.5mm wire (000979225)4.8mm terminals - ATO fuse (large fuses)000 979 023 : 0.5mm wire (000979023)000 979 135 : 1.0mm wire (000979135)000 979 227 : 2.5mm wire (000979227)000 979 306 : 4.0mm wire (000979306)
16 - Centre vent temp G191 (brown) ---> G191 pin 2 (signal)So do I assume correctly that they are both earth's? When I check the sensor itself the connection are one blue and one brown. The blue is the signal wire to the control panel.
Not sure I understand the problem, what's missing in the wiring diagram (and what wiring diagram exactly)?1. How do I connect the rear window heater - I do not found any information in the wiring diagram???
Well, if I only could understand the question Your T17a description certainly points to Climatic AC but then???Do you have an answer to my second question
