Current - is this before retrofit? What kind of control panel (in the cabin) it was originally?You can see the current connection on the picture - only this few wires???
Perhaps time to revive an old thread - unfortunately it wasn't resolved then...Unfortunately, the rear window heating is not working - I had my concerns about this in advance. The light goes on for about a second and then goes off again. Does anyone of you have any idea why this could be?
In what context - engine coding?what is the difference between "Bidirectional Climate Control" and "Semi-Automatic Climate Control"?
Yes, in the context engine coding. Thank you very much.
I chosed the "Bidirectional Climate Control" because that was the description in a thread by Adam_T6 at the very beginning and its control panel looks almost the same as mine.
See text from Adam below:
VCDS coding
Engine control module
Long coding
Byte 3
Select '02 Biderectional Climate Control (Climatic) installed'
So your engine must be 03L...Hello mmi, this evening I tried to chance to "Semi-Automatic Climate Control" but got the report "Error 31: Request is out of range". After that I choose "No OR Manual Climate Control" what was accepted and back to "Bidirectional Climate Contol" was also accepted??? Do you know the reason? Best regards Michael
Hi all,
just resurrecting an old thread, as (in anticipation of the few days heat of the British summer) I'm about to embark on this mod.
I've just been reading through this again to refamiliarize myself with whats involved and the only bit that's got me wondering is mention of the 'center vent temp sensor' (pins 16&17 of the T17A connector above heater box). Is this something at all models have, i,e my non AC manual control will have this sensor already or is it something i still need to obtain/retrofit?
I just want to be as sure as i can be i have all the bits and i can part make up all the looms ready so the vans not in bits for any longer than it has to be.
Thanks all
Hi Sean,Hi folks,
I'm about to get my T6.1 booked into AlipneAir for a AirCon fit.
Potential issues/questions I'm thinking about include:
- On a normal system, if the aircon is on and then I turn of the blowers, the aircon is powered off. Will the "to be system" perform the same, or will I need to remember to turn the aircon off.
- If the "to be system" is simply on/off how hard would it be to get it wired up and coded into the vans system?
- The part of the dashboard when the button is placed, how easy would it be to get a replacement should it prove possible to wire correctly into the van and fit the control unit that has the aircon button?
Thanks @need4speed for the information, I'm glad i asked as i clearly missed his last year when i got all of the other bits.The centre vent temp sensor is actually fitted in the drivers side outer vent. The standard non aircon van doesn't have this so you will need to purchase one and wire it
into the loom.
OK, thanks for the confirmation @need4speed I'll get my hands on one before i start ripping everything apart!Yes the code is for Bidirectional Climate Control, and the system will not operate without it.
