Do this and if it pulls the opposite way you know that there is nothing wrong.
Hi, what instructions did they have to follow and what was the actual cure?Well all I can say as I mentioned before in last 10 years I have driven transporters done over 500000 miles not one pulled to the left. Now I have T32 with 20 inch alloy wheels and was pulling to left so I have complained it was back at the dealer 3 times until today when they followed instructions from VW UK and all is good as it should be.
And by the way I drive lorries now with over 7.5 tunes and no they don’t pull left, doesn’t matter if empty or fully loaded.
Check out post #96 firstHi,
I have a 2017 built VW T6. Its running on aftermarket alloys with 245/45/18 in the front and 255/45/18 at the back. It's been pulling to the left ever since I got it and the local dealership where I am from (Mauritius) is of no use.
Some mechanics have told me to change the damper and suspension which should resolve the issue. Has anyone done that here?
£80+vat
Im in Weymouth and would like this done.
Whos the best person to speak to and arrange this with
Depends who is using the Hunter, I’ve seen some proper dinlo’s trying to use a Hunter. Also, once a tyre is worn on the edge it will continue to pull even after wheel alignment, can you swap front tyres from left to right?Mine now does this, hunter alignment all checks out as in tolerance, so annoying!
Well I had this on my T6. Took it for a Hunter realign twice. Told it was drag on the tyres. Twaddle I thought. Swapped wheels over much better. I then started to swap them all around until I got the best fit. Drives spot on. Better than it has in my ownership.
wheel swap first.
