Quote,
The BCU still knows the static battery terminal voltage and hence SOC.
How, where are the sensors, I am not saying the T6 system is same as Mercs, but the tests on my Merc indicate the alternator is working as a standard alternatot with the neg rail sensor disconnected.
It appears F150 is similar to merc, so is BMW, ford, Honda, VW and many other makes, disconnect neg rail sensor and I believe the smart alternator is no longer smart in those makes, perhaps T6 is different.
VW GOLF
All of what I'm about to say relates to those mk7's that have either the Stop/Start system (it's called "bluemotion" down here - not sure if the same badging happens elsewhere), or an energy recovery mechanism. These cars have a
"battery sensor" that is fitted in-line into the negative battery cable just next-to the battery clamp. The battery sensor (called J367 by VW) also has a connection to a control module called the "Data bus diagnostic interface".
The role of the battery sensor is to determine the condition of the battery (i.e.voltage, current and temperature) and this information is sent to the diagnostic interface in the car. Through this sensor and the previous history of data that it has sent, the diagnostic interface builds-up a picture of the current capacity in the battery. The SOC reading that kenny_c has mentioned is a measure of the past history of the battery since it was first installed in your car and
all the direct battery data came from the "battery sensor".
VW make a distinction between the voltage at the battery and what it calls the "System Voltage", which is the calculated voltage that is available to the car's actual electrical system. All the decisions that are made by the car that reference voltage are taken from the "System Voltage" (not the battery voltage). So, it's real important to maintain the veracity of the System Voltage and incorrectly charging the battery is one way to f&*^k-up this value.
With ANY VW vehicle with bluemotion or an energy recovery mechanism, you should NOT connect the battery charger negative clamp to the negative battery terminal. Doing this by-passes the battery sensor. This means that the battery data is not recorded by the sensor during the charging procedure. The values for the battery state stored in the data bus diagnostic interface then no longer coincide with the real values of the charged battery.
In cars with SS ALWAYS connect the positive charger clamp to the battery positive terminal first. then connect the clamp on the battery charger negative to an earthing point in the car (like a metal component that is screwed to the engine block). This also applies if you are jump-starting the car.
GolfGTIforum.co.uk - An independent forum for Volkswagen Golf GTI enthusiasts.
