Rs components, you should be able to see the stock number.Neat resistor solution Loz, looks better than the standard wirewound. Where did you source those from ?
Which wires did you attach your resistors to please,Fitted mine last week, fitted resistors in the end to correct the hyper flash on the instruments.
View attachment 58186 View attachment 58187
Yes, the resistor cured the hyper flash, It goes across the green & orange (the center pair)Which wires did you attach your resistors to please,
also did you sort your hyper flash
The job is relatively easy, just a case of unpinning and re pinning your wires if your on standard lightsI need these in my life, anyone fancy doing a step-by-step guide how to fit? I have 2018 t6 tailgate. Can you buy the lights from a dealer or is it a eBay job?
Do you get a bulb out warning or did you switch from led anywayYes, the resistor cured the hyper flash, It goes across the green & orange (the center pair)
LED alreadyDo you get a bulb out warning or did you switch from led anyway
Ah that’s why thenLED already
Easy tweak with VCDS though.Ah that’s why then
https://uk.rs-online.com/mobile/p/panel-mount-fixed-resistors/1852396/
My second most favourite online shop, right after eBay![]()
Pin assignment is
1 - brake
2 - Ground
3 - Side light
4 - Fog
5 - Indicator
6 - Reverse
Pin assignment is
1 - brake
2 - Ground
3 - Side light
4 - Fog
5 - Indicator
6 - Reverse
pin assignment is the same on both sides
part no
7LA 945 095 D Left
7LA 945 096 D Right
but I’ve ordered the LHD version for the left to have a double fog light 7LA 945 095 A
fog light is LED in these
@Adams - Did you reuse your original/previous blub holder or was it a full assembly swap with the below part numbers?
7LA 945 095 D Left
7LA 945 096 D Right
LH LightAnyone able to help identify which colours are the wires?
