£34999 Reduced Price. rare
DSG Automatic LWB T6 Campervan is for sale.
Low Mileage (43548 miles) Many extras including)
Pair of 60cm RIB/Seat/Beds on fore and aft sliders, and with Sideways adjustment enabling use as 2 Singles or to form 1 Double Bed. RIB Seats are designed that when in Night Mode, the Seats simply convert to Beds using the reverse sides of the Seats providing a good flat sleeping surface, so you sleep only on the reverse side of where you normally sit, The RIB Seats work in conjunction with the Driver and Passenger Seat which are both fitted with "
Kiravans" seat swivels. The base of the Passenger seat incorporates a lockable
Kiravans Security Safe for any valuables.
All seats have "Simora" finish and are fitted with Seat Belts, so there are 4 Belted Seats. and 3 Berths incl. Roof Bed.
The van was purchased by us during "Lockdown" from Bristol Campers Co. as a Base Camper, already insulated, carpet lined, and fitted with
Grey Altros flooring on ply. The
"Alstops" lifting roof was also professionally fitted by Bristol Campers ,together with roof bed.
Side and rear windows all professionally fitted have Privacy tint.
Planar underbody Diesel Heater professionally installed with Heating Duct Outlet beneath Driver Seat.
LED Interior lighting.
Webasto 12v Fridge
Smev 2 burner hob with smoked glass top
Smev sink with smoked glass top. with fixed waste pIpe to underside of van enabling use of a "Grey Water container.
All rear windows fitted with Blackout Curtains on top and bottom rails.
Tailgate mounted 2 Cycle Rack, fitted with upgraded lifting struts.
Thetford WC mounted within a rear cabinet, covered when not in use, and enabling quick and easy servicing of toilet from the tailgate.
Electrics:
12v An AGM leisure battery is located within a built-In housing (also serves as convenient shelf) Served by a CTEK Controller ensuring a topped up battery from the Smart Alternator without draining the Start Battery. A switch panel controls 12v supplies to the Overhead LED lighting, Water Pump ,Planar Heater, and Fridge.
230v
From the external connector through a "Maypole" distribution unit that includes Consumer Unit, Isolator and 13 Amp outlets to 2 double 13amp outlets.
The Van is also fitted with "Front Splitter" and a Rear Spoiler, 20" Alloy Wheels. Parking Sensors, Awning Rail, Reversing Camera linked to screen in the Reverse Mirror.
Cabinets finished using "Driftwood" lightweight Ply. (Done by current owner - Have proved functional for our use ,including a month long tour in France this year, (The van meets current ULEZ requirements and has the French "Crit Air" registration.
Also included:
Foil insulated window infills for Windscreen and Driver/Passenger windows.
VANGO Driveaway Awning with inner bedroom tent.
The Van Layout was based upon the "Rear Kitchen" layouts similar to used by Bodans Campers, and Jerba. We don't use the Roof Bed, so is removed at present, but has been stored together with it's lifting struts and is easily refitted.
NB:
A Solar Panel and Controller is also available, but is NOT included in the Sale,but is available by negotiation.
This Campervan is very easy and comfortable to drive. It is competitively priced.
Service History is available from 2020 on. Serviced by local VW/Audi "Autotek" garage.
Van Location. Clevedon,Somerset. M5 Jct 20
