Under the bonnet - why cut a hole in a panel??
Just a tought, my caravan is white and it has a white cover on the electric hook up so you can get them
Buy Flush-fit Caravan Mains Electric Inlet 240V 16A at Towsure
Well you've just explained my 4 years of horror with my old van/trailer electrics...I feel so stupid! Will be using WD40 from now on.Also good preventive maintenance to spray inside with WD40 to keep the contacts clean and corrosion free just as with trailer electrics connections
@Jonny it also helps to do the same with the trailer plug and then put it in a suitably sized plastic bag secured with a piece of garden plant wire and stored so that water doesn't run down the cable and into the bag .Well you've just explained my 4 years of horror with my old van/trailer electrics...I feel so stupid! Will be using WD40 from now on.
This!Under the bonnet - why cut a hole in a panel??
Well the next time I easily connect my hookup cable or fill the water tank I shall actually weep at the ruined lines of my box shaped van.
Never had that problem with my towed van as the flap was a vertical slider for the electrics . The flap also stayed white for over 10 yearsI do find ours is very convenient on the side, however, having it underneath would save Mrs Loz from having to jump out at the traffic lights to run back and slap the lid shut every now and then.
Problem was the van was silver and the primer was whiteNever had that problem with my towed van as the flap was a vertical slider for the electrics . The flap also stayed white for over 10 years
That would annoy one with OCDProblem was the van was silver and the primer was white
