I did buy some Hex type Rivnuts to fit into the chassis to mount the cradle to, none existing in my van. The Hex shape stops them turning, and there are already Hex shaped holes in the chassis rails to fit them into.
Hi, the company doing our conversion also fit the heater under the r&r bed (drivers side). How is yours doing, are you happy with placement and how noisy is it? I understand that they all make a little noise when first started the quieten right down. We don’t expect it to be running whilst we sleep though, may get too hot!Good morning, we collect our new t6 conversion next week. The diesel heater is located under the rock & roll bed. Has anyone else had experience of this? We are wondering how to protect the heater from being knocked/moved particularly as this area will be used for storage of items. Has anyone made some type of vented boxing? Thanks in advance
I would suggest in colder weather you will have it ticking over all night, thats what the thermostat is for. Also I would insist that the conversion company put it underslung. Apart from anything it takes up invaluable space if its inside. Just my 2p.Hi, the company doing our conversion also fit the heater under the r&r bed (drivers side). How is yours doing, are you happy with placement and how noisy is it? I understand that they all make a little noise when first started the quieten right down. We don’t expect it to be running whilst we sleep though, may get too hot!
Exactly! I’m warm bodied and used to sleeping outside on winter wild camps so even an unheated van will be luxury. Space wise there’s plenty as it’s just the two of us.No need to run a heater overnight - why run it just to keep your nose warm? Bedding is what keeps you warm at night. Below -10 deg. area maybe you would run at lowest heat.
I agree that that’s a possibility but if you want to avoid a van full of condensation you need to heat and ventilate. The other issue is your other half stealing all the bedding once it drops below 15 deg C.No need to run a heater overnight - why run it just to keep your nose warm? Bedding is what keeps you warm at night. Below -10 deg. area maybe you would run at lowest heat.
Mine's a 2KW heater (Chinese) with hot air ducting running from below the driver's seat, across under the exhaust (heat wrapped) and up under the passenger seat. No concerns yet about heat loss, so I've not insulated the ducting.The heating air pipes can be lagged if you feel it's worthwhile, have with one version that had rather long plumbing but not generally
