Not sure about any issue with cancelling epass (can you not cancel but just not use it...? you'd need to make sure that an alternative was the one that was billed and that you weren't double-billed...)...As usual, my trip ideas and research come a little late ?)
I am off to Norway (I hope) in the 2nd week of September. I registered with Epass, and was about to register with a ferry pass too, when i saw this which seems to be combined? Also then I saw someone saying about linking road tolls and ferry passes. Is that straightforward? If I was to register with the Oresund Pay tag I guess I would need to cancel Epass?
I am probably overthinking it, but I sense the possibility of an expensive mistake
Last time i travelled in europe (road trip) was pre Brexit and was on motorbikes
....but covering the other stuff: yes the system/contract we used (via Øresundpay - I set up both number plate recognition and order the 'bizz' tag) handled everything over my trip... toll roads/tunnels, ferries (they are run I think by an arm of the state transport anyway so use same system as other road tolling...?) and the Øresund bridge...
My understanding is that the 'bizz' tag enabled a discount on the ferries which the number plate recognition did not (no idea why!)...? If you have both the 'bizz' tag seems to be the one used. I had numberplate recognition just in case....
As @Bigsidavies mentioned some of the (smaller) ferries used a handheld scanner but I wasn't sure whether that was doing the scanning to bill you or whether it was just checking that you did have a contract set-up (either numberplate or 'bizz' tag)...?
Pretty easy to order and set up (once you get your head around some of the lingo and the slightly overcomplicated bullshit about operators, providers and contracts blah blah).
My account was all just linked to a credit card. No pre-paying anything.
You should be absolutely fine to order now ahead of your trip - mine took a week. All free to set up too via Øresundpay...
PS the cost of all these tolls and ferries is easy to overstate: most of them are really cheap!!
I reckon I spent in total £50ish on stuff in Norway (and quite a bit of that was the trunk road and motorway south from mid-east Norway to Oslo!!) and then £60ish on the Øresund bridge. Most of the toll roads/tunnels and ferries are 2 to 3 quid!! And when you see some of the engineering you do not begrudge it!
