not being rude, but did you read the pdf above? i dont really care on what watts were tested if the homologation certificate shows less than 2000 lumens that the data that i need..Of course, but what W are they registered legally as ?.
I did not see the PDF, I did not presume that you were being rude just pointing out something out that I have missed.not being rude, but did you read the pdf above? i dont really care on what watts were tested if the homologation certificate shows less than 2000 lumens that the data that i need..
Surely if the rules are the same for manufacturer factory fit and retrofit, and they’re offered as factory options, then you may be able to assume that they meet the requirements?I don't follow?
Nope the legislation that we have here in switzerland is that if the lights produce less than or equal to 2000 lumens they dont technically require washers or levelling.In GB the magority of vehicles with OEM LED Head-Lights, have auto levelling of the head lamp. As far as I am aware that is the same for al EU countries and many others. Are you sure that you do not require auto levelling? perhaps it is already fitted to your vehicle?
I am 100% sure that my van doesnt have this, but i am also 100% sure that i will be fitting the lights, levelling and range adjuster - just not the light washers.
this whole thread has been about the oem LED lights which i'm wanting to fit..! The document above shows that these produce less than 2000 so all is good for me..Ah, I take it that you have established now, that your vehicle produce less than, or equal to 2000 lumens? I was not sure that you had. I must have missed something.Well good luck. If you fit all the equipment then no need to have lights under 2000lumens then?
Any way good luck with your venture.
As others have said it’s not a legal requirement. Some early T6s don’t have washers from the factory and T7s also don’t have washers.I had genuine LED headlights and self levelling fitted recently.
Can anyone tell me is it a legal requirement in order to pass an MOT to have headlamp washers fitted With LED headlights.
The MOT guidelines seem a bit woolly and discuss checking them working but not if they have to be fitted.
I've used the search facility but can’t find a definitive answer.
