Nice work, very nice work. I like that, a lot.Guys I can't stop doing this.
I am still managing to keep myself happy as I come up with a new idea almost every week. Have a look below and judge yourselves.
It is not wizardryWhat is this wizadry,how is it done?.![]()
Mate, this is exactly the same diagnosis I was thinking about.It is not wizardry
It’s a medical condition called “VW toyitus T6” it’s a mental condition that generally affect the central banking system . At the moment there is no cure for the illness , the only thing you can do is keep the owner comfortable and supply them with plenty of tea and coffee when they are in therapy (logged on to t6 forum) or tinkering in the garage.![]()
Please share the details of how this is done! I would love to have my new (to me) LED rears with sequential indicators.Guys I can't stop doing this.
is it just not a led strip from eBay,just had a look myself and theres quite a few designs,Please share the details of how this is done! I would love to have my new (to me) LED rears with sequential indicators.
great explanation Robert ,thankyou,might have a look at my own lights, not doing anymore to my van at the moment ,burst my back couple days ago, so now taking it easyThis "job" took me exactly 20 minutes including taking off the lamps of the vehicle and then reinstalling them.
I simply bought 2 led sequential strips and I have inserted them through indicator bulb opening.
Specific length of the strip makes it sitting firmly inside of the lamp without anything extra to hold it in place. Seriously very simple and quick mod with quite impressive result.
One thing bothered me initially cause I thought that OEM T6 rear LED lamps have very narrow indicators and therefore sequential effect is going to be pointless. But after quick inspection I have discovered that there is internal gap between indicator "chamber" and rear fog led "chamber" so I could proceed with this "retrofit"
EDIT: Indicator strip sits partly in front of the rear fog led but it is not affecting its luminosity at all
I have spent €6.32 = £5.50
This is the link to my expensive purchase ----> Buy Products Online from China Wholesalers at Aliexpress.com
How did you manage with the bayonet fitting, @Robert?OEM T6 rear lights are factory equipped with 16W filament bulb for indicator.
My LED sequential strip take 0.33A , which translates to 4W.
This is obviously short by 12W to expected 16W and results with hyperflash and double frequency click in the instrument cluster.
Required indicator additional power(wattage) = 16W - 4W = 12W
P = U x I ---> I = P / U = 12W / 12V = 1A ===> R= U / I = 12V / 1A = 12Ω
So the selected resistor was 12Ω and for sufficient heat dissipation 50W seems to be sufficient.
My resistors---> RS PRO Panel Mount Resistor | RS Components
Credit to @Loz for resistor type and resistor layout inspiration![]()
I have crimped theseHow did you manage with the bayonet fitting, @Robert?
Ah yes, it’s a wedge fitting and not a bayonet - that makes sense. Nice work and thanks for postingI have crimped these
Cembre Insulated Crimp Blade Terminal 12.8mm Blade Length, 1.5mm² to 2.5mm², 16AWG to 14AWG, Blue | RS Components
at the end of each flying leads(of sequential led strip) and then simply got them plugged in the bulb socket. Insulation on crimping terminal keeps them apart and doesn't allow for any short circuits![]()
