OEM T6 rear LED lights are factory equipped with 16W filament bulb for indicator.
My LED sequential strip take 0.33A, which translates to 4W.
This is obviously short by 12W to expected 16W and results with hyperflash and double frequency click in the instrument cluster.
Available coding adjustment for indicator setup is as follows
BCM 09, Byte 18
bit 3&4 = front/rear/side
00 = 21/21/5 W
01 = 21/27/5 W
10 = 21/16/5 W
11 = 27/27/5 W
The lowest possible setting is "10" which I had already as a factory setup so the only solution was to add extra resistor.
Quick maths
Required indicator additional power(wattage) = 16W - 4W = 12W
P =
U x I --->
I = P / U =
12W / 12V =
1A ===>
R = U / I =
12V / 1A =
12Ω
So the selected resistor was 12Ω and for sufficient heat dissipation 50W seems to be sufficient.
My resistors
RS PRO Panel Mount Resistor | RS Components
Credit to
@Loz for resistor type and resistor layout inspiration
