P2006 (Inlet Manifold) and 15560 (EGR) errors 2016 T6 150
Rmgcook
I've FINALLY got into this forum - didn't realise hotmail addresses don't work.
I have a 2016 150 T6 DSG with 70k.
2 weeks ago the coil light came on and the van kicked into limp mode. Later that evening the emision control light came on
Initially I used a basic code reader and pulled the following code:
P2006 Intake Manifold Runner Control Stuck Closed Bank 1a
2 days later, no lights on the dash and van driving fine again.
I took the van to my local van centre - they scanned and said there were several errors, so cleared them and asked me to drive until I experienced a problem.
On my way home from the garage, when pulling away from stationary, the van went really rough for a few seconds (not done this before) - it cleared itself, and drove home fine. However, the coil light reappeared that evening.
I decided to upgrade my crappy OBD reader and bought a Carista. Plugged it in and pulled the code 15560 EGR Sensor "A" Circuit Range/Performance.
I reset this to test when it appears - every time stop/start kicks in, if stopped for more than around 45 seconds, I get the error 15560 EGR Sensor "A" Circuit Range/Performance. I've cleared the code and tested it around half a dozen times - the code reappears so I think is consistent.
The van has run fine during the day and no lights on the dash. If didn't have Carista, I wouldn't know there was something going on.
I've done a lot of reading today and found one post which has my current symptoms - 15560 error after a long stop / start but van seems to run OK. Unfortunately the post doesn't say what the fix was but he was suggesting he may replace the EGR:
I believe the EGR valve sends exhaust gas into the intake manifold. The original error I had from a basic code reader was P2006 Intake Manifold Runner Control Stuck Closed Bank 1a.
Now I'm seeing 15560 EGR Sensor "A" Circuit Range/Performance (and one occurrence of the van running rough at low revs), I'm wondering if it could be the EGR valve that's suspect, and over a period of time, it results in the intake manifold error.
Is this plausible or am I way off?
As mentioned in the linked thread, the 15560/P046C fault code alone (=no other EGR related faults, no dash light) is not a concern.
But if that still bothers the way ahead would be to verify the actual EGR valve operation, e.g. as here
More likely a separate issue, not directly related or consequence of 15560 fault.
Thanks Mmi, I've not had the van long - waiting for the engine light to come on again before I can pull any codes is agonising, I might get the valve tested when it does go in, to rule it out completely. P046C00 / 15560 appears every time after a lengthy stop / start - any idea why that would happen if there isn't a problem?
Based on quite a few postings around the Forum it seems that P046C00/15560 won't turn on any warning light on dash. Of course it's an indication that things are not the same as new. A kind of interesting thing is that - as you have noticed - the fault is registered only when engine is stopped - probably becasue the EGR valve does then a couple of full sweeps - depicted e.g. here - possibly explains your observation about 45 seconds:
However, the P2006 can be a nuisance because of turning van into limp mode.
Some background information here:
More related stuff listed here:
Also would be good to check that ECU is up to date re software updates. Please post "Detailed ECU info"-report (under Carista Service menu).
Sorry for the slow reply, here's the ECU info - not sure whether the software versions are all up to date.
Code:
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Software version: 0736
ASAM/ODX identifier: [none]
Coding: 042307 (hex)
[No fault codes]
Engine
Part #: 04L906056KH
Component: R4 2.0l TDI
Software version: 6184
ASAM/ODX identifier: EV_ECM20TDI03004L906056KH
Coding: 0025401C432401080000 (hex)
Fault codes:
15560 Manufacturer-specific code
Transmission
Part #: 0BT300046A
Component: DSG DQ500-7F
Software version: 5206
ASAM/ODX identifier: EV_TCMDQ500021
Coding: 0014 (hex)
[No fault codes]
ABS
Part #: 7E0907379P
Component: ESC
Software version: 0132
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: 617E4098256B847F8675027BA48A21D2790000 (hex)
[No fault codes]
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: 01 (hex)
[No fault codes]
Airbags
Part #: 7E0959655E
Component: VW10Airbag00C
Software version: 0016
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: 000000000000000000000000000000003043 (hex)
[No fault codes]
Instrument cluster
Part #: 7E0920970L
Component: KOMBI
Software version: 1008
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 470B010300 (hex)
[No fault codes]
Infotainment system
Part #: 5C0035680C
Component: MU-S-ND-ER
Software version: 0245
ASAM/ODX identifier: EV_MUStd4CTSAT
Coding: 06570001FF00000011111101008808001F0100C6002001004F (hex)
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907040H
Component: ClimatronicT5
Software version: 0509
ASAM/ODX identifier: EV_ClimatronicT5
Coding: 0004000103 (hex)
[No fault codes]
Auxiliary heater
Part #: 7E0963273
Component: STH-T5GP2
Software version: 0007
ASAM/ODX identifier: EV_AuxilParkiHeateWOST5G2
Coding: 4101 (hex)
[No fault codes]
Parking/steering assist
Part #: 7E0919475S
Component: PARKHILFE 8K
Software version: 0210
ASAM/ODX identifier: EV_VW75XParkAssis8K
Coding: 11810C (hex)
[No fault codes]
Central electronics
Part #: 7E0937090
Component: BCM PQ25 Max4
Coding: A0A4393A0A61349281284F646CEB8ED48DB4698960CC6960320400BF0840 (hex)
[No fault codes]
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 330B1A73 (hex)
[No fault codes]
Trailer
Part #: 1K0907383F
Component: Anhaenger
Software version: 0100
Coding: 0100000100000000 (hex)
[No fault codes]
