A single sheet 3100x1500mm B\BB quality of 10mm ply - Okoume Marine costs 120EUR in the store.Saves starting a new thread so...... Is there a floor packer/batten kit available? Saves me trying to order a large sheet and making it myself.
Seen one on ebay but its £80
You wouldnt need anywhere near that size, its only a few battens to make the floor level. I'm not on about the full floorA single sheet 3100x1500mm B\BB quality of 10mm ply - Okoume Marine costs 120EUR in the store.
I couldn't see any for less than that when I was looking a couple months back. In the end I refused to pay their bonkers prices and bought some ply and made them myself. Only takes a few hours if you've got a jigsaw, or table saw would be better I suppose.Saves starting a new thread so...... Is there a floor packer/batten kit available? Saves me trying to order a large sheet and making it myself.
I bought packers and flooring from my local conversion company. I think the packers worked out at about £20 so worth going to ask rather than onlineSaves starting a new thread so...... Is there a floor packer/batten kit available? Saves me trying to order a large sheet and making it myself.
When you glued the batons what pressure did you use on the batons so that all batons were equally level?View attachment 140329
All bonded and battened, I used puraflex 40 from tool station for bonding, 9mm marine ply B&Q.
Took the kombi seat brackets out by dropping the fuel tank and cutting 3 holes in the heat shield by the exhaust to get to the others, all put back tidy.
I put the lashing bolts back in thier holes and used the sealant/ bonding adhesive to fill the holes from where the kombi seats were nothing will be coming through them holes lol.
That'll do!!
Spirit level to be level with ribs?That'll do!!
Depends if the ribs are.level!!Spirit level to be level with ribs?
On a 2023 t6.1vl i would hope so unless used as a builders van.Depends if the ribs are.level!!
Yes of course. If you place long batons held down by a reasonable sized weight across the ribbing with glued down packers that should keep them level.It should be. However, my tongue in cheek comment was referring to how the van is sitting.
A spirit level is useless if the van isn't actually parked on a perfectly level surface!!
spot on thank you job for the weekend i thinkPretty sure we used 2x 1/4 sheets (4x2 ft) for ours without too much left over.
I'm away from van/home at the moment, but if you're happy to wait, I may still have my cut list somewhere in a notebook.spot on thank you job for the weekend i think
aye i can do mate let me know when cheers plenty of other bits to doI'm away from van/home at the moment, but if you're happy to wait, I may still have my cut list somewhere in a notebook.
Beautiful nice one pal@josh_mccoskery Here you go mate. Two 4x2 sheets
