View attachment 63322 Hello @rtg1200 ,is the top of your dash a lighter grey or is it titan black as in the caravelle lowers or the upper dash in a highline/comfort dash? Its a crap photo,i will take a better one tomorrow,thanks
Thanks @rtg1200 , shame because those panels are pretty expensive but the beige needs to go!
Thanks for the pictures. The finish looks good, how is the durability?I’ve had a go with some Buzzweld PIO (Plastic in one)RAL 7021it’s not too far away from the upper dash but it’s different to the Titan black doors
first off remove all the fittings for the sun visors and lights etc, then seat belts stays and b-pillars, then gently tease the headlining out pulling - towards the front of the van - and then let it dropHow easy is it to remove the cab lining ?
did you give this a go at all?Has anyone found a good match for the Titan black yet?
Found this an the web as an alternative TRG Black Vinyl Dye Plastic Paint Aerosol 150ml or 400ml 317 has anyone tried it yet?..
I need to paint the lower B pillar trims to match the VW Titan black door cards and lower dash
Any useful tips or good or bad products greatly appreciated.
Thanks Paul
