have a look here >
https://www.olearymotorhomes.co.uk/ekmps/shops/olearys/resources/Other/pms3-instructions.pdf
Power Supply/Charger The PMS3 employs a fully automatic mains to 12 volt DC powersupply/charger which is able to provide a stable output voltage, even under load.
The unit is capable of providing upto 12 amps, should this be exceeded then the PMS3 will enter current limit mode, thus preventing damage to itself and 12 volt electrics. The PMS3 will, if necessary, operate on a mains supply as low as 207 volts (making it ideal for low continental voltages) and still provide a stable (regulated) dc output voltage. To use the power-supply/charger place the rocker switch marked CHARGER SUPPLY on the front of the unit to the ON position, it should then illuminate.
Battery Selector Switch
VAN position When in this position dc power is available from the caravan/motor-home battery to power all 12 volt electric circuits. If the charger is switched on, the battery will be charged up via the charger/ transformer unit.
OFF position With the charger/power-supply off, this position isolates all DC power in the caravan/motor-home. Note: The switch should be placed in this position when the caravan/motor-home is being driven between locations.
CAR position The switch can be placed in this position should the caravan/ motor-home battery become discharged and no mains power is available. Power will then be drawn from the car/main battery to power all 12 volt electric circuits.
Battery Condition Meter This electronic meter provides a 5-bar LED readout of the condition of your main or auxiliary battery. Readings should be taken as follows:
High region Fully charged (no charge necessary)
Norm region Adequate charge (re-charge if desired)
Low region Low charge (turn on charger to re-charge)
Pump Isolation Switch This switch is used to isolate power to the water pump in the event of a pump fault or merely as a safeguard against unwanted pump operation.
