P
Phil_G
Guest
Thats right
One last question, honest How does adding that charger marry in with the PMS build-in charger?What is the meaning of life? This one will suit you VICTRON IP 65 12/7 Bluesmart | travelvolts
Hi Phil
Thanks for your reply, is Martyn actually travelvolts ? I'm just in conversation with him at the moment with regards travelling down there and getting whatever is needed to sort it all out![]()
Hi Andyhi Andy,
Definitely worth the journey down, at least that way you can collect the gear you need and I’m sure Martyn can explain how to do it. Or get him to fit...
Andy
No! You will need to disable theBit of an old thread to reply to, but I've tried without luck to find information.
I've got one of these PMS3V/H systems in my van. I've had a sealed lead battery running since I got the van without issue, seems to charge and discharge well enough via a mixture of mains plug in and Sterling B2B charger off the main van battery. Always had a couple of summer days off grid use with a fridge on low and standard phone / laptop charging which I thought was good.
I'm now wanting to upgrade to e.g. a 200Ah Lithium Iron Phosphate battery for longer off grid wild camps.
Will the PMS charge the battery correctly? There's no option to set what battery type you have like you can do with the Sterling. Can I just swap out the lead battery and replacing it with a lithium one?
Thanks for any help.
That bad?No! You will need to disable the
PMS "charger" and fit a more sophisticated one such as a Victron 12/30
The PMS is designed primarily for cheap caravans. A caravan is normally only used on a site with a mains hook up. The "charger" is really just a power supply that takes over from your leisure battery which in theory rarely gets used so does not require much charging.That bad?
Do you know what the actual point of the PMS that’s in my van? The conversion is only just two years old on a 2018 T6, yet these PMS's seem to be from a different era. Are they mainly for managing 240v supply to your van electrics, but also charge the battery as a 'bonus' albeit a charger that can’t fully charge your battery? My fridge seems to run via a separate fuse, leaving only the tap, lights, 2 sockets and 2 12v sockets being powered via the PMS.
Basically yes. Depending on how your 240 volt circuits have been there will most likely be a spare output at the back of the PMS where you can connect the new charger to save using up one of your sockets. Don't turn off the battery switch or you will cut off the 12 volts to your pump etc. Turn off the breaker that supplies the charger.So I need to disconnect the charger element of the PMS without also cutting power to the 240v sockets in my van. I'm assuming that's as simple as turning the Battery switch on the PMS to OFF when I'm hooked up. Then I get a proper smart charger (e.g. a Victron Energy Blue Smart charger that can charge all battery types). Charging the battery when on hookup would then be via the new charger plugged into one of the vans 240v sockets.
