PMS 3h - Power Management System
@Ollie1 Put more info on with details of model of fridge and how wired into the van. As @Pete C says
Thanks all, appreciated.
The fridge is a waeco, mobicool, 12/24vdc 0.3w. Its wired straight from the leisure battery I think with a separate isolating switch.
So is it OK to use a smart charger plugged directly into the 240v outlet into the leisure battery? And presumably ensure the rocker is in the neutral position so it's not being charged twice?
And would it make any odds if I'm in Europe, ie does the pms still output enough from the 3pin plug socket?
And so with a pms when you're driving around the leisure battery is not being charged? Or only negligible charge?
Thanks again,
Ollie
@Ollie1 Yes use the smart charger plugged into your 240v socket with the rocker in any position as long as the in built charger is off. It will work just the same in Europe. The PMS does not charge whilst you are driving. You will have either a charger relay for that or a B2B charger (which I doubt as you have a T5 without regenerative braking.)
