Not sure you call it auto latching.. or soft close! Either way my van has decided to soft close when it feels like it! Sometimes it does and sometimes it doesn’t. Has anyone else had issues like this?
The door and van have had 3 stage sound proofing and insulation. Would that cause it due to weight? I wouldn’t have thought it was faulty only being a year old.
any help would be much appreciated
@Jayjmac @Deaky
Mine is having exactly the same issue.
It's a LWB Highline @ just over 15 months old, and never had the problem previously.
Just over the last 6 weeks or so, most of the time it works fine, then just when you think it has fixed itself, you pull the handle (hearing nothing) and it fails to operate the motor for the power latching when opening / closing, and you have to help it to shut, try it again and then it starts working again.
I have parked it on uneven ground - still the same
I have parked it on level ground - still the same.
Checked, both the male & female side of the contacts, all look good.
No apparent broken bits.
Mine has also had sound proofing and insulation, which was installed from the conversion company, when the T6 was a week old, so I can't imagine that the problem was due to this or it would have been like this, since then.
It's very frustrating, as if I took it to the dealers, I know it would work ok!!
I did manage to video it, but I don't think the dealers will accept this, it has to "not work" when they try it.
I wonder if the door contacts need a little grease on them, or should they be dry?
