Can anyone advise on possible locations to fit an Power magic pro please? I don't really want the box in view but I would need to access it as required.
Mine is under the left hand end trim of the dash. It’s not immediately accessible although the trim is easy to remove.
In some ways it would be desirable if it were fully accessible but the only reason I would need this is to turn the dashcam off if I wanted to save vehicle battery depletion. The disadvantage however is I would probably forget to turn it on again! That’s why I just unplug the dashcam power and hook the supply lead over the rear view mirror as a reminder. It’s not ideal to often unplug/ plug in, but I’m less likely to forget to start it up again.
