Power Steering Pump - Replacement Procedure
I will keep you posted! Strange thing happened yesterday. I decided to not be so light with the steering. I went lock to lock as fast as I could for around 30 seconds. The steering went lighter and the vibrations/noise was drastically reduced. I went for a drive and it felt close to no issue and great. When I stopped and reversed onto the drive, it went heavy again and vibrating like mad. I also have this strange thing where if I turn it to full lock clockwise, it gets about 1/4 away from the end and goes spongy. I can force it through the last bit but then when steering it back, it vibrates and makes a loud noise.
Very similar to what I had the first time round. I suspected it was an airlock at the time, but it was too late - the poor pump installation has killed the pump (hence the swarf).
So update time!!
The steering us now working as it should.
Advice: Don't use non genuine ps pipes even if they look to be the same etc... I had one made and matched to my original one by a local hydrolic company. On inspection I found big chunks of swarf within the pipe and this could have been what killed my original pump. I mean getting rid of swarf on pipe work is pretty standard stuff and I am shocked they left it in this state. Anyhow, it's all sorted now and back to how it should be.
So update time!!
Great news and perseverance!
