Friday,12,August,2022,13:04:28:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 22.3.1.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 56 61
VIN: WV2ZZZ7HZHX017101 Mileage: 118440km-73595miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXGB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KB HW: 04L 907 445
Component: R4 2.0l TDI H02 6189
Revision: 23002001
Coding: 00114014432401090000
Shop #: WSC 24822 002 1048576
ASAM Dataset: EV_ECM20TDI03004L906056KB 004015
ROD: EV_ECM20TDI03004L906056JT.rod
VCID: 77FD5EDBCECD4D37FE-8023
VINID: 9E60AAAAA1D8A98A00047040049B3EF3DB
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 43416000000070
Coding: 307E4098256384850C760276A48321F3780000
Shop #: WSC 35110 790 50316
VCID: 3F8DF6FBA67DB577F6-806B
Address 04: Steering Angle (G08ª) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 13101613471418
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C7FBD-802B
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AJ HW: 7E0 907 047 AJ
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 72EB6FCFA5AF281FC9-8027
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 329160591
Coding: 62A0303A0A212032002009746C2B8CD40F80708F60CE4D60320400220800
Shop #: WSC 35110 377 08192
VCID: 2A5BB7AF45FF20DFB1-807F
Subsystem 1 - Part No SW: 7E0 959 801 M HW: 7E0 959 801 M
Component: J386__TSG_FT 003 0653
Serial number: KU0KU024111663293934
Coding: 0400A0
Subsystem 2 - Part No SW: 7E0 959 802 M HW: 7E0 959 802 M
Component: J387__TSG_BT 003 0653
Serial number: KU0KU023111663283715
Coding: 1400A0
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag020 H08 0018
Revision: -------- Serial number: 003V30030T5V
Coding: 000000000000000000000000000000003230
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A7B87EFBD5F905FC1-806F
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 860 S HW: 7E0 920 860 S
Component: KOMBI H03 1104
Serial number: 00000000000000
Coding: 150B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 387F9DE78353824F37-806D
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042205
VCID: 68DF0DA79B73D2CF67-803D
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1104
Serial number:
Coding: 000000
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADB77AF8D7FE0DF71-803F
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5614
Revision: -------- Serial number: VWZZZ4H6290655
Coding: 0E000240020005
Shop #: WSC 127395 840 08317
VCID: 4683E31FF1A7E4BFB5-8013
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 181
Mileage: 118446 km
Time Indication: 0
Date: 2017.01.02
Time: 13:57:34
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 030B7A73
Shop #: WSC 29383 004 1048576
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001611151252
End-------------------------(Elapsed Time: 02:31)--------------------------
