thanks. Went with 38psi as its not overly loaded, not to max capacity anyway. Will get some new boots and adjust pressures
Put the pic on the wheels in motion forum.My T6 California Ocean has same issue, excess wear on outside edge of R/N/S
Last week had Hunter lazer alignment checked, no issues found!
30mm VW lowering springs, all Tyre pressures 48psi
Having new rear boots fitted on Monday, any advise grateful received
Rear passenger
Need a capital D in @DellmassiveHi..
Bilstein b14 mate 50mm lowered. Rear sits a little lower than the front.
And I think...
Rear tyres 275 / 40 r20 . Fronts are 245 / 45 r20. The fronts I'd have to double check.
The rear tyre I have posted has a bubble / egg feel on the inside edge. The drivers rear is now a new one because I had 2 screws in it. That's how I've come across the excessive wear. The fronts have excessive wear also on the inside.
Just like to say @dellmasive, thanks for all your vids and posts you do for the forum. It's helped me dellmasivly..
Hi Mate could do woith these setting for a T6.1 please?The settings we have are for lowered T6's that are either pulling left or right, or they have uneven tyre wear. If yours is lowered with one of these problems, drop me a PM with your mobile number and I will shoot the settings over by WhatsApp.
