Rear Tyre Excessive Wear
thanks. Went with 38psi as its not overly loaded, not to max capacity anyway. Will get some new boots and adjust pressures
My T6 California Ocean has same issue, excess wear on outside edge of R/N/S
Last week had Hunter lazer alignment checked, no issues found!
30mm VW lowering springs, all Tyre pressures 48psi
Having new rear boots fitted on Monday, any advise grateful received
Put the pic on the wheels in motion forum.
Tony the alignment guru will suggest some revised settings
Hi all.. I'm getting super excessive inner rear wheel wear . And need to get it on a hunter alignment machine.. does anyone know of a garage in or near Wigan that would know what no load is. And how to adjust the rear wheels.i have a kwik foot near me. It's a 2016 carravelle.. thanks in advance. Maybe list the garages that you guys have had success with. And post settings.. sorry. Just to add did anyone get the bolts and nuts renewed ad it says in the manual
What size tyres and suspension setup?
Standard?
Got pics of all 4.
And a side view of the van to see how it sits?
Gotta say it's not looking too bad...
Mine is is worse ..
Standard sportline setup... 50psi. Heavy load.
Hi..
Bilstein b14 mate 50mm lowered. Rear sits a little lower than the front.
And I think...
Rear tyres 275 / 40 r20 . Fronts are 245 / 45 r20. The fronts I'd have to double check.
The rear tyre I have posted has a bubble / egg feel on the inside edge. The drivers rear is now a new one because I had 2 screws in it. That's how I've come across the excessive wear. The fronts have excessive wear also on the inside.
Just like to say @dellmasive, thanks for all your vids and posts you do for the forum. It's helped me dellmasivly..
Hi..
And I think...
Need a capital D in @Dellmassive
Cheers mate.. they've not taught me that in college yet. We are only upto youngs modulus and airflow calculations at present.
I've come across a vw audi specialist in Irlam called awesome. They do 4 wheel alignment.
I'll post a few pics later of my sportline alloys when I swapped them for the banded steels...
The settings we have are for lowered T6's that are either pulling left or right, or they have uneven tyre wear. If yours is lowered with one of these problems, drop me a PM with your mobile number and I will shoot the settings over by WhatsApp.
Hi Mate could do woith these setting for a T6.1 please?
