Reclassification as a Motor-caravan: don’t bother
Does it not get judged on vehicle classification that would provided / generated by the dvla records?
No
The DVLA themselves say that the V5 classification is irrelevant to speed limits.
But the police cameras still issue (automatically) tickets to innocent van drivers as they wrongly use the DVLA database.
I know it’s lengthy but it’s all explained in this thread, including a copy of a letter from the DVLA admitting such which you can print and keep.
Sounds a bit like lucky dip in a minefield :rolleyes: Mine is brand new professionally converted camper interior, sink, cooker, heating system, water tank, pop top, crash tested bed, 1 x sliding side window, microwave.......wonder if they would still class it as a panel van o_O
Van with windows is what you will get, unless bought brand new from one of the favoured convertors.
What page is the letter on ?
This one I believe
It wont even get to court, there is a letter template now that you can use to send to the police force who issue the speeding fine.
I have searched high and low for this template but to no avail. Could you enlighten me please :)
Nope I very much appreciate your help though.
Try expanding this quote:
Speed limits for Transporters - as well as the current position of camper conversions not being reclassified as such by the DVLA - have been extensively discussed on the forum, culminating in precedence being set that a Kombi* as well as a converted campervan* can legally travel at car speeds on single & dual-carriageways, even though the vehicle may not have been reclassified from a N1 Light Goods Vehicle to a M1 Passenger Car.
*Kombi - see dual-purpose vehicle requirements here:
*Campervan - motor-caravan / motor-home vehicle requirements here:
Various threads can be found across the forum, some stickied and locked, and are easily located using the following:​
Tag ‘Speed Limit’ | T6Forum.com​
Tag ‘Reclassification’ | T6Forum.com​
Post 345280 shows an example letter a member sent back in response to receiving a Notice of Intended Prosecution from a Safety Camera Partnership authority alleging his T32 Kombi was travelling at a speed exceeding that which its class was permitted by law to do (see www.gov.uk/speed-limits for more information on what speed a LGV, amongst other types, can legally travel at).
In summary, the letter points out
  • That it appears the NIP has been generated based on a recorded speed of 72mph on a national speed-limit (NSL) dual-carriageway,
  • That the belief by the operator / computer generating the Notice was that the vehicle was a LGV, therefore the speed limit for that type of vehicle for a dual-carriageway would be 60mph,
  • That the vehicle is in fact registered as a ‘dual-purpose vehicle,
  • That, in claiming the above, the member proves with photographs that their Kombi unladen weight was less than 2040kg limit, was constructed to convey both good and passengers, is fitted with rear transverse seats, and has windows fitted to the side and rear.
  • That the Notice has been generated in error as no law has been broken (NB: the fact they acknowledge they were recorded as driving at 72mph does contradict this, but with discrepancies in speedometer readings, most authorities do allow some leeway).
The text of that example letter is quoted here:
Ultimately, the authority wrote back to that member and confirmed the NIP would be cancelled and no further action taken against them.
Provided your vehicle was travelling within the speed limit set for its classification, and meets the requirements of a dual-purpose vehicle / motor-home, then there should be no reason to prosecute for for excess speed by type of vehicle within England or Wales (Scots law differs, and there is an ongoing thread on that here, which will inform how their law interprets this matter).
Should an authority continue to press ahead with a prosecution, that does not necessarily mean you would be found guilty of speeding at Court. The two example letters below would help you prove this to the Court, pointing out the differing opinions of one authority (a safety camera partnership) to another (the driver and vehicle licensing agency) where you can demonstrate you were adhering to the speed limit set for your vehicle..
Post 335533 shows a letter a member received back from the DVLA after they sent in their V5 Logbook with covering photos and a letter requesting the vehicle be reclassified as a motor-caravan fallowing it being converted.
In summary, the DVLA letter stated:
  • DVLA were not willing to amend the classification because the vehicle was not externally recognisable as a motor-caravan.
  • The camper was evidently recognisable as a ‘van with side windows’.
  • That, regardless of the refusal to reclassify it as a motor-caravan, the camper could still be used as one.
The text of that DVLA letter is quoted here:
Post 334169 shows a letter two members have received back from the DVLA after both making separate enquiries as to whether their vehicles were subject to lower speed limits given they complied with the DVLA-specified requirements to what they recognise to be a motor-home (see the Gov.UK link mentioned above for said requirements).
  • Vehicle speed limits are determined on how the vehicle is configured for use, namely carriage of passengers, carriage of goods, or both.
  • The V5 Logbook ‘body type’ should not be used to determine the vehicles’ speed limit.
  • That, should the vehicle meet the DVLA requirements needed to be recognised as a ‘motor-caravan’ / ‘motor-home’ then it should be treated as having the speed limits of such.
For more information on the DVLA and reclassification as a MH / MC, see this thread:
This post has been written by a forum member based on the posts and threads found within the forum. The forum, by its very nature, is merely a tool for sharing information, so naturally can not be held liable for any prosecution or conviction a member or guest here receives based on the details imparted. Both legislation and its interpretation by Courts, as well as policy decided by government authorities and organisations such as the DVLA, can change over time, which could render this post incorrect and outdated. I speak independently of the forum when posting this thread. Therefore I would recommend you seek your own independent professional legal advice, this post simply being a collaboration of views I have read being expressed on T6F.
So mine is classified as a motor caravan when I got the V5 - was converted about 4 years ago (I’ve had it about 8 months) have not had to try and get it reclassified.
For those that do and are struggling this might be an option but obviously have not had to try!
Under the data protection act you have a right to have personal data to be corrected. So maybe worth someone trying this (as does not cost anything) and say your personal data is incorrect and you want it corrected. Be interested if it works, quoting GDPR and the right to have data corrected and if it is not you will complain to the Information Commissioner Office (ICO) this makes corporations nervous about not getting it right.
That’s a novel approach! I don’t think it will work but it’s a new angle to try! :thumbsup:
Unfortunately it doesn't meet the definition of personal data...
“‘personal data’ means any information relating to an identified or identifiable natural person (‘data subject’); an identifiable natural person is one who can be identified, directly or indirectly, in particular by reference to an identifier such as a name, an identification number, location data, an online identifier or to one or more factors specific to the physical, physiological, genetic, mental, economic, cultural or social identity of that natural person”.
If you yourself have had wrong data assigned to you - age, ethnicity, personal credit rating, etc - then you could apply to have it corrected.
A van is not a person, so being registered incorrectly doesn't fall under the aegis of personal data.
Trying to challenge the registration is pointless as unless there has been an error - say, it's body type is listed as saloon or it has two wheels - as it's the DVLA that create and assign the vehicle classes following instructions from parliament, ie, they decide what's right.
FYI
Personal data includes a registration number
What kind of information could allow an individual to be indirectly identified?
The following is a non-exhaustive list of information that could constitute personal data on the basis that it allows for an individual to be singled out from others:
  • car registration number and/or VIN;
Khan's TFL database incorrectly records my historic vehicles as needing to pay congestion charge - I'll await getting a ticket and then report it to the information commissioner for holding incorrect personal data about me.
FYI
That's been tested in court several times with a negative result.
Where it starts to get messy is that information linked to a VRM could indeed be defined as personal data under law, but weasel words in the legislation permit the DVLA to distribute it to those they feel have good cause. The legal challenges to that have thus far come to nought.
Good luck with TFL. The incorrect data they are using is about your vehicle, not you. Your cars emissions are not a characteristic relating to you as an individual.
Best of luck.
