Sold RENOGY DCC50S 50A DC-DC charger + BT2 Bluetooth adapter
Dellmassive
VCDS User
Moderator
T6 Master
RENOGY DCC50S 50A DC-DC charger + BT2 bluetooth adapter
i was running a couple of these,
this one now available for sale, as its been sitting about for ages.
£190 + UK shipping
or delivered to Busfest-22.
50A dc-dc charger, but can be set to 10/20/30/40/50A via APP
has all charge profiles needed, including Lifepo4 and User.
works with DC HOME app.
DESCRIPTION
【Multi-input for Battery Charging】 Renogy DC-DC On-Board Battery Charger is designed to charge service batteries from a starting battery linked to an alternator or by utilizing solar panels connected directly to the unit, offering multiple charging options and ensuring your battery stay fully charged.
【3-phase MPPT Charging Technology】 With Built-in Maximum Power Point Tracking (MPPT), Renogy DC-DC On-Board Battery Charger will charge your service batteries with maximized solar power, providing 3-phase charging (Bulk, Boost and Float) to regulate the whole charging and ensure the batteries will be accurately charged at the correct voltage levels to 100%.
【Multiple Protections】 Renogy DC-DC On-Board Battery Charger has multiple intelligent protections includes battery isolation, over-voltage protection, battery temperature protection, over-current protection, overheat protection, reverse current protection, solar panel and alternator reverse polarity protection, guaranteeing charging safety and protecting you batteries.
【Light & Small, Ready to be Set Up】 With only 244mm in length, 146mm in height, and 1.42kg in weight, Renogy DC-DC On-Board Battery Charger is ready to be installed and adapt to any tiny narrow installation space, resolving your concern from limited room in you vehicle.
【RJ45 Communication Port Featured】 Bluetooth Monitoring Ready! Exclusively available with the BT-2 Bluetooth Module accessory and Renogy DC Home App available on the IOS and Google Play Stores, you can monitor this device remotely and simply through your phone and stay constantly updated.
1662393982268.png1662394014379.png1662394053016.png1662394041818.png1662394033594.png1662393992236.png
