Hi all looking some advice on fitting a Renorgy DCC30S dc dc charger mppt controller to my t6. Seems its a common enough compoment but i can find the info im after regarding fitting to a t6. Vans got a 100w solar panel and im just going with an 95ah AGM battery all mounted below drivers seat,
Do i take the neg back to the starter batt or do i use the chassis ground ?
d+ signal wire im reading 3 different methods and not sure what route to take,. Pick up a ign feed or engine running feed from center fuse box or go down the BCM module route picking up on the AUX battery separating relay active.
Would also like to instal a battery shunt but would like to get my head round the main install first.
Any pointers most welcome.
cheers D
cheers D
