Seconded. With a LiFePo I hope the BMS would step in and try and break the load but I wouldn't rely on it succeeding or not being damaged in the process.If you've ever accidentally touched a spanner between battery terminals you'll know it gets very hot, VERY quickly! So fuse as close to the battery terminal to reduce any unprotected wiring.
I've been in the bay when a mechanic dropped a spanner across the exposed terminals of a 24v truck battery set. The current welded the spanner and quickly heated it to the point you couldn't touch it, by the time a lever was found the batteries were boiling and gassing oxygen and hydrogen which led to a fire. Something you don't forget in a hurry.
