Fault clears okay when plugged in to VCDS. Can anyone help out ?.
Code:
Wednesday,07,September,2022,09:16:27:21591
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZJH195406 License Plate: BT68HZG
Mileage: 39380km-24469mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZJH195406 Mileage: 39380km-24469miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KL HW: 04L 907 445
Component: R4 2.0l TDI H02 3802
Revision: 23002001
Coding: 00194014432401090000
Shop #: WSC 02762 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KL 004003
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 015C8C87018C4F73E8D-8054
VINID: 9E606AAAA1D8A9A60124510018673AB5FD
1 Fault Found:
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [236] - Efficiency too Low
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 39123 km
Date: 2048.01.01
Time: 10:57:45
Engine RPM: 1580.75 /min
Normed load value: 31.0 %
Vehicle speed: 89 km/h
Coolant temperature: 91 ∞C
Intake air temperature: 19 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.359 V
Unlearning counter according OBD: 40
Air mass at air mass meter 1: 111.6 kg/h
Outside temperature sensor 1: B1: raw value: 18.5 ∞C
Mass airflow sensor 1 bank 1 airflow: raw value: 604.6 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 5.05 %
NOx sensor before SCR cat conv: offset correction factor: 0 ppm
NOx sensor after SCR cat conv: offset correction factor: 261 ppm
Reducing agent quality sensor: urea concentration: 0.00 %
Reducing agent quality sensor: raw temperature value: 0.0 ∞C
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 61598000000815
Coding: 307E4098656B84830C790276A68821D379F100
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FD84A7F37F8F983DE9-806A
No fault code found.
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 12061813470967
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F77B7072308B95F-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AJ HW: 7E0 907 047 AJ
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 72BED34B342A64EBE17-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 166180923
Coding: A0FC793A0A61341393284F646CEB8EF40D84718960CC69603304003F0840
Shop #: WSC 02762 022 417748
VCID: 2B000E2FD3007523621-807E
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 140618 05 50 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 R HW: 7E0 959 801 R Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 005 0653
Serial number: KU0KU029051881492645
Coding: 1400B1
Subsystem 3 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 004 0653
Serial number: KU0KU005061881561655
Coding: 0400A1
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 39180001107310018225
Coding: B0FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231808809008
Coding: 10800C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BCDC47312C5FF318D-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 3005180452AA9F
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 36362F5B18C238CB0DF-8062
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 J HW: 7E0 959 655 J
Component: VW10Airbag021 010 0018
Revision: -------- Serial number: 003EK001KWLP
Coding: 000000000000000000000000000000003231
Shop #: WSC 02164 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3D2430773DF4EB93CC5-8068
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1107
Serial number: 00000000000000
Coding: 440B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 3A2E3B6B2CDADCABE97-806E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042307
VCID: 688AB12302769E3B4F3-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1107
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8ECB2B1CFAAC2B597-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0472
Serial number: VWZAZ2U0902584
Coding: 065700013C00000011111101008808001F0100C6002001004F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2514F817B5644353B45-8070
Data carrier:
Subsystem 1 - Part No SW: 3G0 919 866 M HW: -----------
Component: ECE 2016 --- 0521
Serial number: --------------------
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030B7A73
Shop #: WSC 02762 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75885700001806040A22
End----(Elapsed Time: 01:50, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
