Replacing LB Battery - what Ah & spec AGM?
I turn it off, but the odd time I forgot, then yes it did work.
Pete
To be honest, the issue I had was that my existing battery died completely.
I did try to code it in with Carista, but not convinced that worked.
Stop/Start started working immediately.
Peter
I have recently replaced my starter battery. The OEM was a 75ah Varta and the replacement was 80ah Varta which was exactly the same dimensions. I had no issues changing the ah’s and serial number with Carista.
The bigger the better as long as the physical dimensions fit the space in the van.
Pete
If you fit a bigger battery you’ll need to code it other wise the van will only initially charge it to about 80%of the old battery capacity.
Hi, I bought a MIDAC 70ah battery and now they tell me that there is no coding for this battery, so would anybody know what the best default coding would be for this battery, or what coding would work best?
Look at @mmi post here. The only critical bit of info is the capacity. I'd suggest the following coding 070 [pick anything from the list] [add one to your existing serial number listed]
Reactions: mmi
