Can I ask you clever chaps a question or two please? If I were to replace the above said battery (like for like) and couldn’t get it coded straight away, would it throw any fault codes? And after a while would the van just accept the new battery without coding?
This is an interesting thread for me at the minute…. I have exactly the same battery as @jordanL and last week I had two or three consecutive days when my van didn’t start up as it normally does…. normally I turn the key and it fires straight up, but last week it would crank over a few times first. Is it new battery time I wondered?
When I bought my van it was two years old…. I’ve had it now for four years and not touched the battery, so assuming it was the original when I got it, that battery is now six years old.
If you replace like with like, there shouldn't be any fault codes, but the charging system will not know that a new battery has been fitted and adapt to that until it has been installed for some time.This is an interesting thread for me at the minute…. I have exactly the same battery as @jordanL and last week I had two or three consecutive days when my van didn’t start up as it normally does…. normally I turn the key and it fires straight up, but last week it would crank over a few times first. Is it new battery time I wondered?
It will work, its just that the charging strategy will not be optimalI've been wondering about the coding of it myself and wonder if it'll still work and be temperamental or not work at all?
Many thanks for your reply SirIf you replace like with like, there shouldn't be any fault codes, but the charging system will not know that a new battery has been fitted and adapt to that until it has been installed for some time.
However, if you upgrade but fitting a higher capacity battery or an AGM battery, it would be advisable to recode. Carista is a relatively cheap and worthwhile tool to have and you can use it to recode.
Thank you Mr Reaper, just ordered one of these from those guys, you should be on a commission! Many thanks![]()
S5 A11 Bosch AGM Car Battery 12V 80Ah Type 115 S5A11
S5 A11 Bosch Car S5 Battery - AGM (Absorbent Glass Mat) Bosch Group are one of the leading battery manufacturer companies in the world and have been delivering quality German engineering in the automotive industry for more than 100 years! Bosch is a world renown company name that have and still...www.tayna.co.uk
A pound cheaper and it has a 5 year guarantee over the Varta 4 year one.
For a little bit more the biggest that will fit is the S5A13
Battery Group is a little cheaper on delivery too.![]()
Bosch car battery S5A13 start-stop 12V 95Ah 850A
Bosch S5 A13 car battery AGM Start-Stop 12V 95Ah 850A The S5 A13 is a battery from Bosch. When developing batteries, Bosch relies on…batterygroup.co.uk
